MCBr 15 Late 2013 + W9100 - NEED HELP
arveen
(@sabharwal)
i ran the automate script
findings:
About this mac:
i don't see the W9100 in the overview
System Report:
graphics/displays:
AMD Radeon HD 8xxx:
  Chipset Model: AMD Radeon HD 8xxx
  Type: GPU
  Bus: PCIe
  PCIe Lane Width: x8
  Vendor: ATI (0x1002)
  Device ID: 0x67a0
  Revision ID: 0x0000
  gMux Version: 4.0.8 [3.2.8]
Upon connecting a monitor to the eGPU:
Nothing happens.
can pls anyone help where have i gone wrong.
Mac Pro 2013 - D700 - Sonnet Echo III TB2 - AMD W9100 - OS 10.13.6 High Sierra
Macbook pro late 2013 - GT750M - Sonnet Echo III TB2 - AMD W9100 - OS 10.11.6 El Captain
nu_ninja
(@nu_ninja)
Did you set the eGPU display as primary as shown ithis video?
arveen
(@sabharwal)
i cannot see the eGPU in my displays
arveen
(@sabharwal)
***      automate-eGPU.sh v1.0.1      ***
* (c) 2016, 2017 by Goalque & FricoRico *
Detected eGPU
 Hawaii XT GL [FirePro W9100]
Current OS X
 10.11.6 15G22010
Previous OS X
 10.11.6 appstore
Latest installed Nvidia web driver
 [not found]
Checking IOPCITunnelCompatible keys...
IOPCITunnelCompatible mods done.
Rebuilding caches...
All ready. Please restart the Mac.
Arveens-MacBook-Pro2:Desktop RVN$
arveen
(@sabharwal)
@goalque
can you help pls.
goalque
(@goalque)
Apple doesn't support W9100.
goalque
(@goalque)
arveen
(@sabharwal)
Posted by: goalque
https://blog.maxsaxedesign.co.uk/2015/11/01/mac-pro-dual-amd-firepro-d700-dual-amd-firepro-w9100-egpus/
I've found this post where this user was able to PnP not one but 2 w9100 without any script with the mac pro 2013 D700
and also got a chance to speak to him and confirm that they still run without any problem..
i was hoping since u guys are Guru's of eGPU you could throw some light and help me out with this setup.
goalque
(@goalque)
I checked that 0x67a0 device id doesn’t exist in 10.13.6. The old automate-eGPU.sh adds missing ids and might work in Sierra but I have ceased the development and don’t provide any support for scripts. Sorry. Did you try automate-eGPU.kext? (discontinued as well)
arveen
(@sabharwal)
Posted by: goalque
yes, starting from 10.13.4
https://support.apple.com/en-us/HT208544
so if i stick to sierra or lower os will this setup work.
will try install sierra and then try the old scripts.
sorry for taking ur time bcos im unable to get this setup working and not a very experienced user so asking for your help.
thanks
