Hello everyone,
I'm planning to install purge wrangler soon combined with purge-nvda.
My setup:
- Macbook pro late 2013 with geforce 750M/TB2/ OSX catalina 10.15.7
- Razer core x Chroma (used)
- Sapphire RX 5700 xt nitro (used)
- TB3-TB2 adapter
- TB2 cable
I read that it is mandatory to proceed the installation of purge wrangler manually with the egpu unplugged. So my question is about the options I've to choose: I will set AMD GPUs and I wonder if I need to install the TI82 support?
Is there something I forgot?
I also use bootcamp, how to set the egpu in Win10
Thanks in advance
Cu
Macbook Pro Late 2013 (750M) OSX 10.15.7 - Expected egpu Razer core X - RX5700Xt
TI82 is for old Thunderbolt 3 devices created before Macs started supporting Thunderbolt 3. The Razer Core X does not have the TI82.
In the eGPU.io Buyer's Guide, only the AKiTiO Thunder3 has a TI82.
As for the rest of your questions, look for answers in similar Thunderbolt 2 Mac builds that use Windows 10 in the eGPU.io Builds list.
