Share:
Need Help: NVIDIA 1080ti > AKiTiO Thunder 2 Box > Thunderbolt 2 > MacBook Pro (Retina, 15-inch, Mid 2014)
(@jens_jensen)
March 14, 2019 8:45 am
My System just only recognised a NVIDIA Chip Model, see my system report. Any ideas how to fix this.
I had running this configuration on MacOS 10.12. without any issues. Today I updated to High Sierra, without success.
My configuration:
MacBook Pro (Retina, 15-inch, Mid 2014) / NVIDIA GeForce GT 750M 2048 MB & Intel Iris Pro 1536 MB
AKiTiO Thunder 2 Box (original Bizon Box 2 Case)+ modified with bequiet!  PSU + Nvidia 1080ti
Thunderbolt 2 connection without any adapter
macOS configuration
1. Disabled SIP with csrutil from Recovery terminal
2. run @mac_editor's Purge-Wrangler without TI82 activation
3. run purge-nvda with option 2 without success
Thanks in advance
Jens
Probably I have no rights to add some screenshots to this post or I can't figure out how to do this.
Quote
natemac00
(@natemac00)
March 18, 2019 7:52 pm
Purge-wrangler works on my 2014 MBP, be sure not to connect the eGPU till after you log into HS and you're at the desktop.
I'd rerun purge-wrangled, do the uninstall, restart and run it again, be sure no issues are with the driver you're downloading. I'm on 387.10.10.10.40.118, and it works fine.
3D Cinema 4D/Octane Artist
Gigabyte Aorus GTX 1080 Gaming Box w/ TB2to3 Adapter
2013 Mac Pro
2014 MacBook Pro
