Hello guys....
my head hurts after reading so many guide about "how to enable nvidia hdmi on mac osx sierra"
First, i try to mount EFI partition on mac . successfully with these command
Fakhrys-Mac-mini:~ fakhryhasan$ diskutil list
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.1 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS MACMINI12 451.2 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
4: Microsoft Basic Data BOOTCAMP 48.0 GB disk0s4
/dev/disk1 (disk image):
0: Apple_partition_scheme +188.3 MB disk1
1: Apple_partition_map 30.7 KB disk1s1
2: Apple_Driver_ATAPI 2.0 KB disk1s2
3: Apple_HFS Java for OS X 2015-001 188.3 MB disk1s3
Fakhrys-Mac-mini:~ fakhryhasan$ diskutil mount /dev/disk0s1
Volume EFI on /dev/disk0s1 mounted
And after that i can see mounted efi volume as in screenshot. okay now i know where to put the patch.
there are a few folders and file inside as screenshots below.
okay now i know where to put the patch. but i need more thorough inspection first. comparing dsdt patch tutorials i found that dsdt on native machine is way different than hackintosh... sigh...
I have question.... is it safe to install clover and patch using DSDT?Since hackintosh has different dsdt and ioreg info... did anybody ever try to patch manually without installing third party application such clover or hackintosh kext? AFAIK dsdt patch is usually patching HDEF and Gfx or PEGP. but i only found HDEF.
instead found GFX or PEGP, i found address
aargh i need rest.... later i will find again any sources. Frankly I want to make this eGPU installation with less modification so i can enjoy both os without any problems... if somebody knows about how to make this work please guys reference me anything would be helpful for brain food.
Thanks Guys.
