Odd interaction between eGPU and Thunderbolt monitor, disabling external GPU
LackingUtility
(@lackingutility)
I've got a Mid 2015 Macbook Pro with an internal AMD Radeon R9, and I hooked it up to a Sonnet eGFX with an NVidia GTX 1060, and everything's been working beautifully. I was running 3 external monitors off the 1060, plus the laptop's internal, and everyone was totally happy.
But then I decided to hook up my Thunderbolt Display, too. Why, if 4 monitors are good, 5 monitors are better! Suddenly, performance was crawling. I looked in the About screen, and low and behold, the Radeon R9 was trying to run all 5 monitors, and the GTX 1060 wasn't even showing up. Unplug the Thunderbolt Display, reload the About screen, and there's the GTX running 4 monitors again. Doesn't even need a reboot - plug in Thunderbolt Display, all 5 on the Radeon; unplug it, all (remaining) 4 on the GTX.
Screenshots attached.
Anyone have any ideas?
Running High Sierra 10.13.3, and NVidia Web Driver 387.10.10.10.25.156
Screen Shot 2018 12 19 at 12.21.14 AM
Screen Shot 2018 12 19 at 12.21.26 AM
Screen Shot 2018 12 19 at 12.22.39 AM
Screen Shot 2018 12 19 at 12.22.32 AM
Screen Shot 2018 12 19 at 12.23.41 AM
LackingUtility
(@lackingutility)
Additional bit of info... If I close the lid on the MBP, then the GTX powers the three monitors it's connected to and the Radeon powers the Thunderbolt. Much improved (but at the loss of the internal monitor).
Screen Shot 2018 12 19 at 12.35.11 AM
"About this Mac" doesn't always show the correct information as far as which GPU powers which display. Can you open up System Information and go the Graphics/Displays tree to take screen caps? The Radeon R9 M370x dGPU should power the internal display and Thunderbolt Display while the GTX 1060 eGPU should power all monitors directly connected to its ports. The sluggish behavior you observed when the Thunderbolt monitor was connected might be due to shared bandwidth on a single Thunderbolt 2 controller. Download and run CL!ng to check with and without Thunderbolt Display connected.
2018 Mac Mini [8th,4C,B] + RX Vega 56 Nano @ 32Gbps-TB3 (Gigabyte Gaming Box) + macOS 12.0 & Win11 [build link]
LackingUtility
(@lackingutility)
You're exactly right... Display info is incorrect, but the System Info>Graphics/Displays tree properly lists the internal and TB Display off the R9, and the three externals off the GTX. Thanks!
That looks like it, too... Device to Device transfer drops by about 5GB/s when the TB Display is connected.
Welp, good to know it's just a bus limitation that I can address with my next upgrade, and not a bug.
@lackingutility Thank you for the update of your findings. Glad you got to the bottom of it.
What does "Device to Device transfer drops by about 5GB/s" mean?
amartinez1660
(@amartinez1660)
Woah, wait.
So a MacBook with a dGPU does work with Thunderbolt Display in the end?
I arrived to the conclusion that it just doesn't work.
I got a Mid 2014 15" GT750M and Apple TB Display.
Posted by: @amartinez1660
Woah, wait.
There's no reason why your Apple Thunderbolt Display shouldn't work with your MacBook Pro (Retina, 15-inch, Mid 2014).
https://support.apple.com/kb/sp704?locale=en_US
Maybe you have a bad Apple Thunderbolt display. Have you tried it with any other Thunderbolt Mac? Have you tried a different display with your MacBook Pro?
amartinez1660
(@amartinez1660)
Forgot to mention, with a eGPU that is.
What I understand, then, is that the eGPU enclosure can be connected at the end of the TB display and the whole set of things Daisy chained (MacBook -> TB Display -> eGPU) would work?
LackingUtility
(@lackingutility)
Don't know, I'm not daisy chaining. I've got the TB display on one TB port and the eGPU with the 1060 on the other port powering three external displays. Works great (with the caveat of having to reboot to plug or unplug the eGPU).
