Sharing My Experience with eGPU Solution (Sonnet Box 550 and Radeon RX 5700 XT)
Salah9
(@salah9)
In the past 2 or 3 months, I checked a couple of articles, posts and Youtube videos that promote the eGPU solution to overcome dGPU bottlenecks in iMacs. So, I bought Sonnet Box 550 and Radeon RX 5700 XT to try the eGPU solution by myself. The result was unexpected!! The performance was lower than the Vega 48.
Here are the results of both GPUs. Both results for the internal display of the iMac.
Unigine Valley (ExtremeHD)
Vega 48: 2355
RX 5700 XT: 2319
Also, I did 1 more test by using 2018 MacBook Pro + external monitor
Unigine Valley (ExtreemHD)
RX 5700 XT: 2590
Are those normal results?
tsakal
(@tsakal)
@salah9
can you please post your exact configuration system and os versions
A. 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Razer Core X, Nitro+ RX5700 xt 8Gb, LG 32UK550
B. 2.7 GHz I7 4 Cores, 16Gb, 1TB MBP 13 2018 TB3 , EGPU Gigabyte Gaming Box RX580 8Gb, Mac OS Catalina 10.15.2, Ext SSD Windows 10 1803
C. 3.1 GHz I7, 16Gb, 1TB MBP 13 2015 TB2 , EGPU Gigabyte Gaming Box RX580 8Gb
galad
(@galad)
Unigine Valley uses OpenGL, and OpenGL on macOS is quite meh. OpenGL on a eGPU is even more horrible.
The eGPU has already less bandwidth than the integrated one, looping it back to the internal monitor doesn't help.
macOS RX 5700 drivers need some performance tuning, 10.15.3 seems a bit better.
You should try to benchmark a Metal game. Shadow of the Tomb Raider for example.
Salah9
(@salah9)
Posted by: @tsakal
@salah9
2019 iMac
macOS: 10.15.2
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 32 GB 2667 MHz DDR4
GPU: Radeon Pro Vega 48 8 GB
2018 MacBook Pro
macOS: 10.15.2
Processor: 2.9 GHz 6-Core Intel i9
Memory: 32 GB 2400 MHz DDR4
Posted by: @galad
I already did a test with an external monitor. The results are not quite impressive at all. Also, I tried World of Warcraft, which uses Metal API, and the FPS is lower than the dGPU that comes with the iMac
I’m not surprised. The Vega is a decent card with very well optimised drivers in the best possible physical hardware set up (pcie). The 5700xt has worse drivers and is being limited due to tb3.
MacBook wise, you are only using a single performance reference metric, you’ll need to test further.
