Will it work (MBP 15" 2017 rp560 with mantiz venus rx580
Maximus
(@maximus)
Dear readers,
I am planning to buy a mantiz venus and a rx580 to go with it.
My questions:
1. I have a 15" mbp with radeon pro 560, will i need to edit anything in the sorts of drivers to make it work?
2. should I upgrade to High Sierra for this, or is it better to stay in Sierra?
thank you in advance,
Maximus
Reinhard1004
(@reinhard1004)
Should work plug & play in high sierra.
https://egpu.io/macos-high-sierra-official-external-gpu/
Late 2016 15" MBP w/ Radeon Pro 460, 2m CalDigit TB3 cable, Mantiz Venus eGPU case, NVidia GTX 1080ti.
Maximus
(@maximus)
How about windows?
Will internal acceleration work in either osx or win10?
Reinhard1004
(@reinhard1004)
Should both work.
MacOS out of the box.
Windows will needs some hacks, but should be easier with the 2017 MBP model (less error 12 to be expected).  https://egpu.io/bootcamp-setup-guide-tb3-macbook-pro/
