Inquiring on r/Razer about this led to the revelation that the RBA actually vents partially out of the keyboard - meaning having the laptop closed in a dock would actually be detrimental, especially while using the internal dgpu. If I was using an egpu with this laptop, would the offloaded thermal overhead fix this problem, as only the cpu would be producing heat inside the laptop at that point? Or would the cpu still produce enough heat to potentially damage the battery/screen? Dock in question would be a Satechi... but if someone knows of a solution more similar to this https://hengedocks.com/products/vertical-macbook-pro-2-0 , then that would be much appreciated.
