AMD Radeon rx 5700 xt and Razer Core x Chroma running in Macbook pro 15" 2017 (B...
AMD Radeon rx 5700 xt and Razer Core x Chroma running in Macbook pro 15" 2017 (Bootcamp)
 of  4
elgalo87
(@elgalo87)
Finally yesterday i've receive my new Radeon rx 5700 xt and the Razer Core x Chroma,,, have to say is not just plug and play i have to do some work around to finally get the card working..
If somebody needs help with this topic please leave your comment. Ill upload pictures of the card running, performance and driver's links.
Best Smile
System Config.: MacBook Pro 15"-2017-OS-10.14.6-(CPU-2.8GHz Intel Core i7-RAM-16GB 2133 MHz LPDDR3-GPU Internal - Radeon Pro 555 2GB + intel HD Graphics 630 1536 MB)-(eGPU-Enclosure Razer Core x Chroma-eGPU-GPU AMD Radeon rx 5700 xt MSI)
Dibi
 Dibi
(@dibi)
@elgalo87
Got mine too, can’t seem to get it working can you help?
2018 13” MacBook Pro w/ Touchbar
Razer Core X + RX5700XT
elgalo87
(@elgalo87)
@dibi Hello and i'm sorry for the delay :). All you need is download a modified drivers, from here https://mega.nz/#!1MZBBAiD!bbvIizUGLzgn-njPfZaOSuQ-j_hWWFp09w2fJmH6vrchttps://www.bootcampdrivers.com/ and follow the steps in the README file...The card run smoothly and no errors or so, been testing all weekend and all good so far Smile LMK how it goes. Best Smile
elbert
(@elbert)
Posted by: @elgalo87
How does it work with your MacBook Pro on macOS 10.14.6?
This post was modified 11 months ago
shishpt
(@shishpt)
Hi I am a new user to this site and wanted to contribute to this topic.
I live in Iceland and ordered both of these devices for my Macbook Pro 15 (2018) and LG 5k monitor.  There was a bit of a hiccup as I first ordered the 5700XT and the Razer Core X instead of the Chroma, however I received the Chroma today and went to work on setting this up.  Prior to this post I could not get this to work.  Then I thought I would give it a shot and try the link that @elgalo87 posted.  I also connected my TV to the HDMI on the back of the Razer device as my 5k monitor connects via thunderbolt to my mac and didnt want to test with that right out of the box.
I was able to get this to work in Windows Bootcamp by following the instructions in the folder.  It takes about 30-45 minutes but I was able to get it to work on the TV.  Now I will try and get this to work on the 5k.
Thanks for this post it did help me in my setup.
elgalo87
(@elgalo87)
@elbert Hi, I think should work on a MacBook Pro 2018, i test it ok a MB 2017. Best
elgalo87
(@elgalo87)
@shishpt
Awesome man !!! And I’ll tell something is going to work For your 4K monitor, I test my
with a Samsung serie 6, and work just fine.
Im glad you find this post helpful. Enjoy:)))
Timstech0128
(@timstech0128)
Could someone tell me how to use macbook pro 2019 13 inch with razer core x egpu with rx5700 on bootcamp with extra moniter
Is that difficult and what will be happened without a extra moniter
And can i use a egpu on bootcamp without a extra moniter
shishpt
(@shishpt)
@timstech0128
I am not sure if it will work.  While I had the e-gpu and card that you had I could not get it to work.  I did not however try the method @elgalo87 mentioned earlier.  If you have the devices I suggest trying it out to see if that solves your issue.  If not then I suggest using the Razer Core X Chroma.
Regarding your monitor, if you have a display port or hdmi connection on your monitor it will work.
Using the e-gpu on Bootcamp without a monitor works for me if I use the AMD software, where i have to try and set the games or apps to use the 5700xt graphics card.  Some work fine others are stuck at 555x (macbook graphics) and I am still wrestling with those games and apps to switch to 5700xt
elgalo87
(@elgalo87)
@timstech0128
Try the method I’d mention above, but before make sure you update windows (bootcamp)
and I would use it with an external monitor for sure. Good luck 😉
This post was modified 10 months ago
 of  4
