Share:
Aorus 1070 Gaming box + Razer Blade Stealth Help!!!
Brian404
(@brian404)
May 24, 2018 4:47 am
Hello everyone im in need of dire help!!!
I recently purchased a Razer blade stealth and a gaming box 1070 from gigabyte.
I install my drivers and stuff the card is detected by my computer perfectly.
But when I restart windows and I reattach the eGPU again, the thunderbolt icon pops up the unit is connecting but the GPU doesn't function until I uninstall and reinstall the driver then it works again..
Any ideas I need some help asap!!
Thank you.!!!
Quote
theitsage
Famed Member Admin
May 24, 2018 1:24 pm
What model year is your Razer Blade Stealth? Have you run all available updates from Razer?
94 external GPU build guides
Brian404
(@brian404)
May 24, 2018 2:34 pm
I have the 2017 Stealth with the i7 8550u the most recent one. And I’ve run all updates through synapse and as well as windows update,
when i uninstall the driver the computer sees it in task manager, but still unable to use the egpu. When I install a older driver it would work until I restart the computer.
votehart407
(@votehart407)
July 20, 2018 8:50 pm
hi
Were you you able to get things working?
Thanks
Razer Blade 14 7700hq UHD - Razer Core X Modified with Kracken G12 and SFF 600w PSU - Titan X Pascal
