Bootcamp with Vega 64 -- Mac won't extend as second screen (with monitor connect...
Bootcamp with Vega 64 -- Mac won't extend as second screen (with monitor connected)
Adam Ash
(@adam_ash)
Hey guys,
So yesterday I installed Bootcamp on my mac, plugged in my eGPU and was excited to see everything just worked as expected (despite all the threads saying I'd have to make loads of changes to the system). However, something weird is going on. I have a monitor connected to my MacBook, which is working find, but my MacBook has a Windows logo and I cannot seem to extend to that screen.
I'm worried that there might be some image burn or something. Is there a hidden setting or something which is not allowing me to use my mac screen as a monitor?
@adam_ash, This is the expected behavior when you have an eGPU connected at boot (to Windows). The iGPU/dGPU is deactivated and therefore the internal display stuck at Windows logo and no monitor connected to the iGPU/dGPU would work. You can either use an EFI boot loader to keep the iGPU/dGPU activated or connect the external monitor to the eGPU.
Adam Ash
(@adam_ash)
Posted by: @itsage
Hey, sorry, perhaps I wasn't clear.
The monitor is fine. My eGPU works perfectly (didn't have to do anything it all just worked) but my mac screen just has the windows logo and won't display anything.
So to confirm, I have a MacBook pro connected to a Vega 64 which is connected to a monitor.
When in macOS, the monitor works as does the mac screen. When I hit reboot and hold option (with the GPU still connected) I select windows and let it boot to windows but only the monitor works (connected to the GPU) but my mac screen has a windows logo.
I can use windows just fine, the eGPU is working but I can only use the monitor.
