DevilBox does not work anymore 🙁
[Solved] DevilBox does not work anymore 🙁
Daelin
(@daelin)
i'm using my devilbox with a gtx 1080ti on a macbook pro 15" (2017) for over a year in bootcamp now. always without problems.
yesterday i wanted to start my setup without success. when checking the device manager the GTX 1080ti did not show up.
i checked in macOS if i can see the devilbox under TB devices, but it does not show up. The USB ports of the DevilBox deliver power as long as it is connected to the macbook as usual, so i guess the GPU is working. I also tried all 4 TB ports on the MB without success...
i fear that something of the board in the DevilBox is broken and i have to replace it.
has someone an idea what i could try before buying a new enclosure?
MacBook Pro 15" 2017, AMD RP560
Devil Box + MSI GTX 1080Ti Gaming X
Bricked thanks to rEFInd:
MacBook Pro 15" Late 2013, GT 750M
2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 Ti @ 32Gbps-TB3 (PowerColor Devil Box) + macOS 10.13.3 & Win10 [build link]
(@gareth_rees)
sounds like dead GPU (do fans spin?), try reseating it, eGPU enclosures will work without GPUs, at least mine does.
Dell Latitude 5491 14" BIOS 1.12.1 + Active PCH cooling | Core i7 8850H + liquid metal - https://valid.x86.fr/z6xi8n | 32GB DDR4 2400 | Samsung 500GB 850 EVO | MX130 + liquid metal | Logitech Z-2300 | Razer Death Adder Elite | Corsair K70 Rapdifire | R43SG v1.2 + RX 570 4GB
teltersat
(@teltersat)
Posted by: Daelin
If you're running bootcamp, when you connect the eGPU enclosure you should be able to see the Thunderbolt controller in the Device Manager (and select view by connection to navigate that mess easily). If you DON'T see the TB3 controller, then I would say it's your enclosure's card - otherwise, it's the video card.
MacBook Pro Touch Bar 2017 15" + Mantiz Venus MZ-02 + AMD Radeon Vega 64
2017 15" MacBook Pro (RP560) [7th,4C,H] + RX 580 @ 32Gbps-TB3 (Mantiz Venus) + Win10 [build link]
Daelin
(@daelin)
At the weekend i tried it again, and it worked fine as before, i have no idea what happened...
thank you for your help anyway!
rockevan
(@rockevan)
My setup also encountered this issue. It was working fine intermittently.
I had to turn off the power of eGPU enclosure for three to five days after it stopped working.
After the waiting period, it started to work again.
I am using Akitio Node with GTX 1060 on MBP 15 inch 2019.
Also tested it on MBP 2015, same thing occurs.
Thinking about getting a new card..
MacBook Pro 15 inch 2018
Akitio Node RX 5700
MacOS 10.15.3
Windows Fast Ring Build 19603
