FIXED eGPU Code 31 When Unplug and Plug Hot Swap Issue
samxk
(@samxk)
I have a Razer Core X Chroma and would be getting an Error Code 31 in Device Manager. The graphics card would not be working and the monitor attached to the graphics card would not work.
The ONLY way to get everything working again would be to restart the laptop.
I've done hours of research and came across a solid fix!!
Uninstall Razer Synapse, restart the computer, and you're good to go!
Here are the things I've tried that didn't work:
Used DDU to uninstall all NVidia Drivers and then disable windows drivers auto-install. This didn't fix the problem.
