Hi all,
I've been testing a GC-Titan-Ridge AIC card with several motherboards (msi X399 gaming pro carbon, msi Z390(with TB header), Supermicro X10DRI) with windows 10 1903 (& 1909). I had to short pins 3 & 5 on the TB header and then everything works fine. I'm using a TB3 dock (2 displayport monitors, usb mouse & usb keyboard). Hotplugging seems to work fine as long as the peripherals are connected on boot.
All the computers have 1 problem though: the thunderbolt connection does not activate on a cold boot. I have to unplug & replug the thunderbolt cable for it to become "active". Restarting works fine.
I've tested the setups with several docks (caldigit ts3 plus, elgata TB3 dock)
I have also tested 3 different TB cables so I dont think its the cable.
I have also tested all the firmwares for the titan ridge (V50,v43,v23) and this makes no difference.
Anyone knows why the thunderbolt connection only "becomes active" after a unplug/replug ?
Thanks !
Jo
