Help! Error 43 in Bootcamp MBP 2013 15 (gt 750m) + Akitio Node Lite + GTX 1050 T...
Help! Error 43 in Bootcamp MBP 2013 15 (gt 750m) + Akitio Node Lite + GTX 1050 TI
(@andreas_hoffmann)
Hello. I have a problem. I have a MBP late 2013 15" + Akitio Node Lite + GTX 1050 TI.
I modified the power on the Akitio board by adding a jumper for 12v. This is to use a 12V / 6A power supply. I did everything according to the instructions and from the 5th time - it worked.
But then I installed the Nvidia SD driver - the card started to give an error 43.
installed rEFInd + apple_set_os.efi - the video card is displayed in the device manager, but there is an error 43.
 Clean install, або reinstall of windows, but it didn't help.
Help - how can I get rid of this error?
