Share:
Help with Mouse and Keyboard Causing Crash - 2017 MBP 15" + Vega 64 / Razer Core X
Sideflap
(@sideflap)
March 14, 2019 3:43 am
Hi everyone,
I got my Vega 64 to work properly with a Bootcamp / Windows 10 set-up on my 2017 MBP 15", with an external monitor. My only (large) caveat is that I'm unable to use any peripherals - about 30 seconds after I plug in a mouse or keyboard, the computer freezes and requires a restart. Surprisingly, Bluetooth still works, so I'm assuming this is USB/power related. I've tried both a Logitech and Razer mouse, both of which cause the issue.
I'm plugging the EGPU thunderbolt in the left side of the computer on its own, and attempt to plug my mice/keyboard on the right side.
Tips? Is there a USB controller that I need to install/uninstall/disable in device manager? I see these by default, but aren't sure if they're at the root of the issue:
1. Apple USB Composite Device
2. Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
3. USB Root Hub (USB 3.0)
Quote
(@brandmee_ch_marco_leu)
April 4, 2019 8:27 am
I have the same problem when plugging in USB-c device. (Mouse, HTC Vive Pro) Have you found a solution?
My Setup: MacBookPro Touch Late 2016, i7 2.7GHz, 16GB Ram, AMD Radeon Pro 455 + Razer Core X + Sapphire Nitro+ Vega 64
