iMac Pro 2018 egpu Razer core v2 help.
mrghanim
(@mrghanim)
Hello there,
So baiscailly I do have a question. I have iMac Pro with 2.3Ghz - 18 core 128GB RAM, 4TB SSD and 16GB of Vega pro 64. So now i made a boot camp with 2TB of windows and when i plug my Core v2 which has inside it an 1080Ti 11GB graphics cards. It shows that's it contacted but for some reason when i try to play games it's always on AMD graphics cards. Is there a way to make sure that it's always running on razer core v2? or how can I use my egpu? Vega 64 pro is not what am looking for in terms of gaming and now I can't even play Dota2 with more than 20fps and sometimes it goes to 7... Please help me!
Noble Member Moderator
A Vega 64 should muster more than 20fps in Dota2...
What version of Windows are you running?
mrghanim
(@mrghanim)
Windows 10 Pro i can't change the setting's to 1090 it's always on 3200 and 1HZ imagine 1hz!!!!
1HZ??! Something is very wrong there... what version of Windows 10? 1709? 1803? What does Device manager report under graphics?
mrghanim
(@mrghanim)
its show 2 cards 1080ti and Vega 64 but am not sure how to work it
