Please help with AORUS and Bootcamp
Darylhelpmeplease
(@darylhelpmeplease)
help help help
Hello,
i have a late 2016 MacBook Pro 15" Radeon 450, Aorus gaming box and external monitor.
I have tried countless guides and implementation techniques and am literally at the point of pulling my hair out.
Please can someone help me simplify this process and help me install.
Thankyou
Hi Daryl, read through this recently published guide to set up eGPU in Bootcamp with your 2016 15" MacBook Pro. I've used the same configuration MBP for this guide so if you follow the instructions eGPU will work.
Darylhelpmeplease
Hi there ok so I'm getting somewhere I think but I can't run the gpuswich file I'm getting message
"the code execution cannot proceed because msvcr120.dl was not found. Reinstalling may fix"
what should I do
You need to install 2013 Visual C++ x86 remedy that error.
Darylhelpmeplease
Hi itsage
confirmed stable success!!
MacBook Pro 15" late 2016 Radeon 450 16gb ram
Aorus gtx1070 gaming box
Thankyou so much.
Im running it like a dream.
question.
Can I update windows in boot camp as normal?
And
what happens when mac wants to update ?
MAny thanks
I can't say for certain whether software updates to macOS and Windows would break eGPU. Make sure to have restore points just in case Windows fail to boot.
Darylhelpmeplease
Thanks itsage your help is much appreciated.
