Razer Blade 15 + Razer Core X locks up
grglhrgl
(@grglhrgl)
I have a Razer Core X with a Nvidia RTX 2060 super and a Razer Blade 15 base model with an RTX 2070 Max-Q. The systems locks up when using a two displays on the eGPU. The screen freezes and nothing works - I have to power down the machine. The eGPU is fine, it worked excellent with a different laptop for very long. I did reinstall the graphics card driver and I wouldn't be aware of any other issues. Any idea what is going on and how I could debug it?
Might be related to https://egpu.io/forums/pc-setup/random-freezing-in-windows-10-pro-with-intel-nuci7beh-razor-core-x-gtx-2060-super/
Razer Blade 15 base 2020, Razer Core X + MSI GeForce RTX 2060 Super Ventus GP OC
grglhrgl
(@grglhrgl)
I think I solved the problem. I used DDU https://www.guru3d.com/files-details/display-driver-uninstaller-download.html to uninstall the display drivers (Intel and NVidia) and did a fresh install. Since then I had no lockups so I guess that must have solved the problem.
