I recenlty started playing BF V again with massiv performance issues. My CPU usage is allways at 100% on all cores while my GPU is sitting arround freaking 8-11%.
I changed all settings back and forth, reinstalled Nvidia Drivers and whatnot. I dont know waht to do now.
Regardless of the settings in BF V I get arround 60-70 FPS. On Ultra and on Low. Heaven ist significantly lower in score. WTF is happening with 1903 and eGPU 😕
Anyone with the same issues?
Edit:
8750H
16GB
external Monitor with 144Hz and 1440p
Razer Blade 15 (2018) with Core X and 1080 Ti
2018 15" Razer Blade 15 (GTX1070) [8th,6C,H] + GTX 1080 Ti @ 32Gbps-TB3 (Razer Core X) + Win10 [build link]
Since no one had something to comment I want give a Solution to this:
1. 1903 sucks.
2. Re-Installing Windows and drivers did not solve the problem.
3. The problem consists even with undervolt, different TB3 Cable and different GPU inside the CoreX (1080Ti).
4. The reasen is simple: The 25 Watt CPU limitation of the Razer Blade 15 (2018 Advanced)!
5. The solution not so much: Since the Blade 15 2018 does not have and get the "Creater" Mode, you have to use the "Gaming" mode within the Razer Synapse Software.
The moment you switch to "Gaming" mode, the System will lift the 25 Watt limitation and everything just works fine. CPU is arround 30-40 Watt usage and GPU is running at 100%.
FPS in Battlefield 5 arround 70 on 1440p and ultra. Very nice!
I did not use the "Gaming" in the past because a stupid issue: When switching to "Gaming" mode, the system would overclock the GPU in the CoreX which lead to crashes and black screens in the past.
1. 1903 sucks.
FPS in Battlefield 5 arround 70 on 1440p and ultra. Very nice!I did not use the "Gaming" in the past because a stupid issue: When switching to "Gaming" mode, the system would overclock the GPU in the CoreX which lead to crashes and black screens in the past.
Thanks for sharing. You can still rolling back right? Undervolting cpu is for boosting better performance by making cpu cooler, there’s nothing to do with that cpu usage, 1903 somehow bottleneck your cpu.
I use always gaming mode when gaming with core setting, yes it’s running on normal cpu tdp unlike on balanced mode which is power limited on 25 watt, so mostly I run on max frequency I think I never see it under 3,9ghz and no cpu power limit throttling sometimes maybe gpu, but it doesn’t ruins gaming experience like cpu one, since gpu usage on high 99% which means effective.
You don’t need creator mode, if you’ve afterburner go there and reset gpu overclocking value when you’re on gaming mode, Creator mode on early 2019 Blade 15 runs cpu on higher tdp with no Gpu OC, and weirdly gaming mode on that model applying no gpu OC, means they’re both same. I heard in mid 2019 model they erased it, seems on this new model only balanced and costum which you can apparently set your self.
Only my curiousness, 2018 Blade OC Core +100/ memory +300, what is your card? Because with the cheapest Zotac Mini I was fine with +125 almost a year, no crashing whatsoever from previous laptop before Blade 15.
@plattenschieler, Thanks for posting this solution.
I have a very similar setup and messing around with my Razer Synapse configurations somehow managed to limit my frame rate in Call of Duty to around 60-75 FPS.
I'm not exactly sure what I did, but I was getting so much better performance before, and now I'm crossing fingers that this is the solution.
