What graphics card would be plug and play on bootcamp with the entry level 16inc...
What graphics card would be plug and play on bootcamp with the entry level 16inch MacBook Pro ?
Mitchellaw1994
(@mitchellaw1994)
Hi All
I currently have a razer core X and rx 570 but it doesn’t work at all, can not get rid of error 12 no matter what I try, happy to invest in a more high end graphics card providing it works out of the box. If not I may just have to sell up as it’s been a frustrating time trying to get it all to work.
andygev35
(@andygev35)
None are going to be plug and play...  There will be some configuration required with them all.  This might help, but it's a different GPU albeit AMD.  https://egpu.io/forums/builds/2019-16-macbook-pro-rp5300m-9th6ch-rx-5700-xt-32gbps-tb3-razer-core-x-macos-10-15-4-win10-1903/
2020 MacBook Pro, i5-1038NG7, 16GB RAM, 1TB
Razer Core X
Sapphire Pulse RX 5700 XT Dual BIOS
2020 13" MacBook Pro [10th,4C,G] + RX Vega 56 @ 32Gbps-TB3 (Razer Core X) + macOS 10.15.4 & Win10 [build link]
Noble Member Moderator
joevt liked
