XPS 15 (9550) with eGPU does not boot Red Dead Redempetion 2 when connected
Evian
(@evian)
Hello All,
I recently bough a Sonnet breakaway 550 and equipped it with a AMD RX 5600 GPU. This went surprisingly well and GTA 5 worked directly after.
Only then i bought Red Dead Redemption 2, and it does not start. When i disconnect the eGPU it does start perfectly on my dGPU (gtx960m), and when i connect by eGPU it even recognizes it in the settings in-game, but when i apply the settings and restart the game, nothing happens. When i look in task manager i see it is running for some time before automatically stopping without any error.
I tried updating all drivers, flashing the GPU to the newest version, disabling the dGPU in device manager and running it only on my external screen. Nothing seems to work.
Do you have any idea how to fix it? I'm really disappointed if this doesn't work, because this is kinda the reason i bought the eGPU in the first place
Mini i5
(@mini-i5)
Honorable Member
@evian
Try using the older AMD driver 19.18.1
Evian
(@evian)
@mini-i5, I tried and it did not work. This software is to old recognize the videocard. I tried Adrenalin 2020 Edition 20.1.3 Recommended (WHQL) and still the same problem. It starts according the the task manager, but nothing happens. After about 1 minute is shuts down automatically.
Mini i5
(@mini-i5)
Honorable Member
You need to ask Steam and Rockstar Games support for help, as the issue is on their side.
Evian
(@evian)
@mini-i5, I got rid of the RX 5600 XT and bought a RTX 2060, not a single issues and RDR2 started directly. Thank you for the support!
I guess Nvidia still beat AMD in term of software
Mini i5
(@mini-i5)
Honorable Member
@evian
Glad the game is launching now.
It turns out Rockstar has had a known issue with the Launcher since the game was released.
The RDR2 launcher issue definitely affects Nvidia cards as well.
Some reports say the game will launch for a period of time, then stop.
18173AA8 C24B 4F44 BA16 F729B015D044
EB65D9E5 497A 4416 9785 E4D09D9D2917
047765E1 2D21 4B2E 948B 8E18554B6C2A
B13ED143 5FA6 4572 9AEF 5AD11FC81CEB
3BA44CFE 01F5 41FB B0EE 986091D82967
8E6DF496 5522 4622 B49F 42C00DE1E4BC
637FA526 B53E 4FBC B88E 147FF5619733
3F1D5958 7CD8 4F08 989E 9F3E3E76F962
27ABE21F 7007 4F45 BBB9 201BA1E4CFD5
Evian
(@evian)
Yes i'm known with all the errors of RDR2, however i was not able to find my specific error. The fact is that i simply got no error at all. Furthermore, it tried all the solutions i could find online including the solutions in the pictures. Most post also seem to origin from the period short after the launch, the game is available for at least half a year now and i have found little known errors there days.
Finally, it is good to mention i compared both cards in GTA 5 and the RTX 2060 performed much more consistent.
