Hello,
I've recently built an eGPU that I've been able to install successfully thanks to the macos-egpu script and this community. My goal is to use run Octane Render in Cinema4d.
eGPU: Mantiz Venus MZ-02 enclosure / GeForce GTX 1080-ti STRIX. / Belkin TB3
Machine: 2017 iMacPro on 10.13.6 (17G65)
Nvidia WebDriver: 387.10.10.10.40.105
CUDA: 396.148
Cinema4d: R19.068(Build RB245443)
Octane: 3.08
The problem I'm running into is when trying to run Octane. The card shows up correctly in "About This Mac" but as soon as i launch Octane, it panics.
Any advice/input would be greatly appreciated.
Thanks,
While it should work fine with Cinema4D in limited scenarios, Otoy has some work to do in making Octane stable for Mac. It's really a PC-centric platform that they added Mac support to late in the game with v3.x. Version 4 beta is out now (and v4 in general will be free depending on how you set it up) but I don't believe it's working on Mac yet and v3.x is very unstable from those I've spoken to.
That said I think they're dedicated to setting up a Metal-based workflow for Octane Mac. That will probably also include eGPU support. But it may be a while. They're notorious for announcing something and having it show up a year+ later.
Hopefully they improve their game Mac game. Once goalque's NVIDIA EFI solution rolls out for 10.14 this is a new area that many Mac creatives will want. Octane is hugely popular for a reason and v4 / the versions of 4.x that will show up in 2019 are seriously impressive as a technical achievement
Thanks for your reply. I've tried running 3.08 and 3.07. I'm in an position where i'll need to share files with another animator who uses C4D + Octane on a PC. I'm hoping to find a successful, established configuration that's stable? Or know if I'm chasing my tail.
@wpratt, have you checked the OctaneBench ( https://render.otoy.com/octanebench/)? Is it crashing as well?
Could you post the crash report?
That is not dead which can eternal lie, And with strange aeons even death may die.
@devild I had not tried that yet. But just gave it a run and it crashed in the same place, right after the octane splashscreen. Thanks for the suggestion. Im not running it to a second monitor or running Ghost adapter, do you think that could be causing the crash? i have an adapter on order.
@wpratt, I've been running an eGPU+C4D+Octane combo successfully for quite a while now.
Do you have a monitor plugged into the eGPU or is it simply used for rendering? i.e. you're only using your iMac display.
@imcalledandy Hey! Thats great to hear. Im running an LG superfine as a second monitor, but not out of the eGPU.
Ok @wpratt. I usually have 2 x eGPUs connected to my 2013 Mac Pro / 2017 Mac Book Pro, so I'm not in the exact same situation as you.
You've run the latest version of macos-egpu? Did you manually update the NVIDIA drivers at all? The script is designed to use the best pairing for your system.
@wpratt - looking at my specs I'm using an older version of C4D (19.053 RB224935) and my GPU Driver version is: 378.10.10.10.25.106 - but I've not had the panics you describe...
Another thing to check: in your c4doctane folder make sure you only have c4dOctane_R19.dylib - you don't need the older versions in there.
Interesting. I had to update C4D to R19.068 for it to recognize version 3.08 octane. What version of octane are you running? I also notice youre running OSX 10.13.3 + 4? Im running 10.13.6. I may try to back everything down to your versioning and see if that works. I really appreciate your replies.
