FCPX 10.4.6+ eGPU SLOWER
rr697
(@rr697)
Man guys I’m bummed. Came on here got recommendations to speed up my late 2015 imac 5k and bought a Sonnet 550 + vega 56 to use on the newest version of Mojave. I did the Purge Wrangler setup no problem, geekbench score doubled. Checked the box on FCPX and the rendering and playback is half the speed of the stock 395x card. Really bummed out. I can see the card is working on the gpu history but what gives? Bummed I might have just burned $700
Late 2015 iMac 27” 5k - Sonnet 550w - Radeon Vega 56 ( slower than before)
Sorry to hear it's not working out with your iMac. Which version of FCPX are you running? Do you have an external monitor to test?
rr697
(@rr697)
10.4.6 FCPX the playback is like 15fps, crazy! External monitor to test what?
Massimo Franzese
(@massimo_franzese)
@rr697
The coding logic of final cut is
GPU connected to the display - live tasks
eGPU rendering and sharing (background tasks)
The idea is that while the eGPU is doing background rendering the GPU connected to the display has more resources to deal with live tasks so make sure background rendering is active otherwise you will have zero benefits.
Mac Mini 2018 3.2 Ghz 6 cores
Razer Core X enclosure with Sapphire Vega 64 Nitro
Benq PD2720U
Mini i5 liked
