Final Cut Pro X (FCPX) performance on MacBook Pro eGPU
Antoine
(@antoine)
I'm mostly interested in eGPU system for video editing on my MBPs (late-2013 and 2017 version) and during these past days I've done some benchmarks on real project (not only on BruceX). I've not yet switched to the new FCPX 10.4 version because it does not use eGPU for rendering so I've benchmark 10.3.4 and 10.4 version in Sierra (10.12.6), High Sierra (10.13.4) and the new High Sierra Beta 1 and I'm going to share the preliminary results.
FCPX project is composed by 60 sec. 1080p 25fps 100Mb/s 10bit (4:2:2) h.264 IPB (long-GOP) compressed.
Fx used: Color Finale, FilmConvert Pro, Motion Titles, Neat Video, Ken Burns, Beauty Box
All exports in Master File>Video Codec>H.264 directly in FCPX
System:
- Late-2013 15'' MBP 2.3GHz GT750M + eGPUSapphire Nitro+ Rx580 in Akitio Node with Apple TB3>TB2 adapter. Os x 10.12.6 (automate-eGPU +enable-baffin-CUs scripts)
- 2017 15'' MBP 3.1GHz RP560 + eGPU Sapphire Nitro+ Rx580 in Akitio Node
- eGPU attached to a Dell 27-inch (2560 x 1440) via display port
All duration in seconds.
Screen Shot 2018 01 31 at 12.16.48
Let's start with some data from the late-2013 MBP
 Just rendering duration on plain (no Fx) timeline
Rendering duration (sec.) on plain 1 min. footage (no Fx)
Not much difference in dGPU vs. eGPU as is mainly involved the CPU. Anyway FCPX 10.4  seems not performing well like the 10.3.4
Rendering of n.5 30Mpxl still image for 1 min. timeline with Ken Burns effect
30Mpx KenBurns
Here you'll see more difference because 10.3.4 is taking advantage of the eGPU
2017 15" MBP 3.1 MHz RP560 + AMD Vega FE LC@32Gbps-TB3 (Breakaway 350 + SF600) + macOS 10.14.6
Antoine
(@antoine)
Color Finale, FilmConvert Pro, Motion Titles, Neat Video and a plain render (no Fx) as reference
Data aggregation by Plug-in
2013 all in 126
Data aggregation by System configuration
2013 4plug 126 sys
FCPX 10.3.4 is a clear winner but not that much.
ikir and itsage liked
Antoine
(@antoine)
Neat Video is the only plug-in I have that is possible to select which graphic you want to use even in 10.4. In all eGPU configuration was chosen 6 thread for CPU + the RX580 and only 6 thread when in dGPU.
2013 NV 126
10.3.4 still the winner but follow very close by the 10.4 version of FCPX
Color Finale+Titles+FimConv+Neat Video plug-ins applied all together
2013 allin 126
Still 10.3.4 + eGPU remains on top, follow by the 10.4 + eGPU (Neat video is using eGPU acceleration)
ikir liked
Antoine
(@antoine)
I just got some benchmarks with the Vega FE LC
BruceX 5k/8K
BruceX
GPU RAM does it count!
dre
 dre
(@dre)
Rendering doesn't use egpu in 10.4.1
Vega 64 / Razer CORE X TB3 enclosure
2016 MacBook Pro 13’
2018 intel Hades Canyon NUC
2018 Mac Mini
2019 Macbook Pro 16'
joysthokkins
(@joysthokkins)
That's sad:(
MacBook Pro 2014 750m MacOS 11.1
i9 9900k z390 Designare 32GB RAM, Sapphire Vega 56 + Sonnet Breakaway 650 with Sapphire Vega 64, MSI34wu1
DaVinci Resolve Studio 17.1b5 | FCPX 10.5.1
Username
(@username)
Apple have an awkward way of neuter features long before before have something better to present.
They do need a good old spanking for doing it time after time.
Antoine liked
dre
 dre
(@dre)
Posted by: Username
I'd be less pi$$ed if they hadn't listed the products that were compatible and then either deliberately removed the functionality or were too damn lazy to fix the bug.
The thing is, there's nothing hardware wise that come near to the VEGA power without spending HUGE money on the iMac Pro.....I'm just hoping the Hades Canyon makes a good hackintosh and I can get something better than a macbook pro, doesn't come with an expensive screen I don't want (or need).....
2018 Mac Mini
joysthokkins
(@joysthokkins)
Davinci Resolve 15 - ❤️❤️❤️ - uses everything from my macbook pro 2014: 750m (not disabled) + vega 64; Rendering is faster than a realtime playback.
That’s sad, because i love fcp’s magnetic timeline. Neat Video fcpx plugin uses eGPU.
Username liked
Antoine
(@antoine)
Posted by: dre
At the moment I don't see any reason for me to move from 10.3.4 to the new 10.4.x till eGPU rendering is not supported. The new features as 360° video support and integrated color board is not relevant for me as I have plugin that will do the job done. I'm very sad for Apple that not support customers that have invested a lot in their ecosystem & apps.
artik liked
