Mantiz Venus + Vega 64 ( LuxMark & Final Cut Pro x )
Mymantiz_John
(@mymantiz_john)
Vendor
*|MC_PREVIEW_TEXT|*
Mantiz Venus High Sierra + Vega 64
We test the Vega 64 in Luxmark Open CL & FCXP
Configuration: MBP 2016 15"
Benchmark: Luxmark
Mode: Hotel Lobby ( Complex Open CL )
Score: 3540 ( Vega ) VS 783 ( Discrete 455 )
Final cut Pro BruceX Test
Redering 5K XML to Quick time movie
17.31 Sec Vega  VS 45.04 AMD 455
Is it natively support? Yes!
Is it hot plug & play w/o system panic? Yes!
Is it enough for a 550W to drive Vega 64: Yes, in High Sierra Pro Apps.
Mantiz Egpu + Vega 64
MBP Discrete AMD Radeon 455
Hotel Lobby Complex Open CL 4973K Triangles
5K ( 5120 x 2700 ) 23.98p
Mantiz: ● ●
AngelRC
(@angelrc)
I just tested my Vega64 and these are the result on macOS High Sierra 10.13.1 Beta 5:
benchmark
benckmark2
Freelancer IT Architect, Analyst & Developer
Macbook Pro 2016 15" 2,9GHz 16GB 1TB SSD Radeon Pro 460
Mantiz Venus with Sapphire RX Vega 64 8GB HBM2 Limited Edition + 3 x LG 27" 4K FreeSync displays + 1 x HTC Vive
Leoben
(@leoben)
I'm very excited of this results! But unfortunately i con't compare: when i plug my mantiz venus and its vega 64 in my MBP, i can't even open FCPX, it simply crashes after 2 seconds. When in the internal display with no GPU, it works. I hoped for an update or something, but now you're telling us it works!! How did you make it?
2016 13" MacBook Pro [6th,2C,U] + RX Vega 64 @ 32Gbps-TB3 (Mantiz Venus) + macOS 10.13 & Win10 [build link]
imcalledandy
(@imcalledandy)
Posted by: Leoben
I downloaded ResXtreme and made sure my displays were running 8-bits/sample. This resolved my issues when trying to open FCPX with NVIDIA eGPUs so it's worth a shot.
2013 Mac Pro (FP D700 x2) [3rd,8C,E] + GTX 980 Ti x2 @ 16Gbps-TB2 (AKiTiO Thunder2) + macOS 10.13.1 [build link]
Leoben
(@leoben)
Wow it worked for me too, thank you so much! now i can hear this little coil wine noise telling me my vega is working for FCPX 😉
mclarenf1
(@mclarenf1)
I heard FCPX 10.4 no longer supports eGPU rendering.
ngthtg735252
(@ngthtg735252)
This mean we can use Vega 64 with Mantiz? Does it provide enough power for gaming (on Mac)?
Macbook Pro 2016 15inch - RP455 with Mantiz Venus Gray + Gigabyte Aorus RX580 8GB => P2715Q 4K 😀
JLSMedia
(@jlsmedia)
Impressive tho I thought FCPX was only using the eGPU for timeline scrubbing right now cuz of a bug? Sucks I'm basically just waiting for whatever eGPU update they're probably putting off till Mojave at this point, I'd like to snag an eGPU now.
ikir
 ikir
(@ikir)
Prominent Member
Posted by: ngthtg735252
You need a more powerful PSU, check my video:
You can see enermax inside Venus here:
my awesome Radeon VII eGPU
Gilles Goetsch
(@ealchemist)
Posted by: JLSMedia
There is a script, which enables FCP export eGPU utilisation.
Sadly the performance is still a fraction of what it could be / was.
