Hi Everyone!
I need your collective help to find what's wrong with my system.
Issue:
None of Adobe CC (2017) can take advantage of CUDA enabled system. CUDA option is visible (not gray) and can be selected. Despite that System use only CPU for playback and rendering.
I post a collection of screenshots that migt help investigation.
Hardware:
Macbook Pro 17 (early 2011) i7 2.33GHz, GTX Titan X through AKITIO Thunder 2 Box.
Software:
OSX Sierra 10.12.3, CUDA Driver 8.0.63, GPU Driver/NVIDIA Web Driver: 10.15.20 (367.15.10.35f01)
Any ideas why I don't get increased performance?
All best,
/IPR
.Did you ever find a solution?
.I read PS and lots of other apps ignore the eGPU if it is not connected to an external display. But I can't confirm if it works that way though.
2012 Mac mini i7 2.6Ghz . 16GB RAM . 500GB SSD . 1TB HDD . Razer Core X . Sapphire RX 580 Nitro+ SE . 60Hz monitor . MacOS 10.14.6 . Windows 10 LTSC 1809
Do you have an external display connected?
.Any more on this?
