For a few years I've always had trouble with Photoshop running smoothly on a MacBook Pro without causing massive throttling and lately that just got worse and worse and worse, to the point that using a MacBook Pro was causing me stress or financial loss. The Radeon VII eGPU helped a little, not much to make a difference. Switching to the officially supported 5700 XT eGPU has done nothing to help.
Looking at the Activity Monitor we can see the problem quite clearly. Whereas on Windows the GPU will accelerate every operation and tool, on macOS the CPU is doing nearly all the work and the GPU is doing almost nothing. The same goes for the internal dGPU and the eGPU.
I present my system energy settings attached, my Photoshop Performance settings, and the Activity Monitor. In the screenshots we see that Photoshop is consuming up to 90% of CPU resources for the most basic functions such as brushing, cloning, transforming, moving layers. The dGPU and eGPU is only hitting between 5-20% utilisation and most of that isn't Photoshop but the Window Server. Performing the exact same test on Windows, we see CPU never goes higher than 10% and the GPU utilisation is 50-60%.
Unless Adobe remedies this situation ASAP, I can't recommend that creatives and creators waste their money on an eGPU for this set up.
Greatly appreciated if everyone reading this can perform the same test and provide screenshots of the same. Will be interesting to see if dGPU in iMacs and Mac Pros are also not being utilised. I've read a few comments online over the years and would like Adobe to understand this isn't acceptable.
I just try to avoid adobe products in general. I hate their subscription model.
sorry that’s of no use to you...
Have you already tried to downgrade to version 2019? Others have reported that the speed increased dramatically after returning to the older version:
https://community.adobe.com/t5/photoshop/photoshop-2020-running-slow/td-p/10719152?profile.language=de
I can check this evening (MEZ) if I have the same problems with version 2020.
Mac mini 2018 i7, Razer Core X with PowerColor Red Devil 5700 XT
https://community.adobe.com/t5/photoshop/photoshop-2020-running-slow/td-p/10719152?profile.language=deI can check this evening (MEZ) if I have the same problems with version 2020.
I could check, but I'd rather move forward and have this performance issue fixed. If I go back to an old version I could be giving up new features and be landed with other types of bugs. If we take steps back and don't pressure corporations to fix their mess then we aren't progressing. It's useful sometimes, but it breeds complacency.
Checking the old version does not automatically mean to change back to the old version. It just could help finding a solution. I think you even can install both versions side by side to compare them and use PS Automation with a batch job (with GPU tasks) and Activity Monitor to measure speed and response time. This info even could help Adobe to fix that problem. It's easier to tell them that something that already worked is broken now, than to tell them that it's just slower than it should be.
I already reported it to Adobe. Just wanted more people to post their Activity Monitor here with different configurations so we have more evidence.
RE: Photoshop 2021 on Macbook Pro 2018 running OS Catalina with Radeon RX 5700 XT
Well the eGPU performance has increased massively.
Photoshop uses 50% CPU and 90% eGPU, excellent performance.
As for Big Sur, the eGPU setting cannot be used in Photoshop 2021, spoke to Adobe tech support and they had no answer, said that two GPU's were not supported, not sure how that excused them but they seemed to think that it did, downgraded Big Sur to Catalina.
.Having said that Photoshop 2021 does not work in Mac OS Big Sur.
What happens is that when the eGPU is selected in the "Performance" setting and a file is opened no image appears in Photoshop 2021 or 2020.
Speaking to Adobe support they told me that a "second" GPU is not supported and has never been supported, even though the option for selecting it is available and that it did work in Catalina.
Not sure what Adobe is playing at.
THE eGPU does work in Lightroom Classic with "Full graphics acceleration is enabled".
Abobe is not doing their job.
.Hey all
Found the answer.
A Displayport monitor needs to be plugged into the Displayport on the eGPU graphics card, then Photoshop 2021 works fine in Big Sur.
That'll do the trick.
.Hey all
Found the answer.
Yes, that has always been the case. The eGPU must be the primary accelerator and connected to the display.
