eGPU to improve workflow and rendering with Vectorworks
The Idea
My actual intention to build an eGPU was to gain better renderspeeds when rendering stage- and lighting designs for visualizations of theatre and event.
So I went ahead, bought an Akitio thunder 2, modified it and was good to go.
My Setup:
- Macbook pro mid 2012 El Capitan
- 2,3GHz Core i7
- 16gb RAM
- NVIDIA GeForce GT 650M 512 MB
- Akitio Thunder 2 with some housing mods
- KFA2 GTX 970 4gb
- Dell DA-2 PSU
Results
What I gained was a serious performance boost for large files with many objects in complex layer and class environments
when working in wireframe mode or open gl render mode.
But when rendering final quality there was no performance boost at all.
After some research I found out that Vectorworks is using the GPU only in wireframe and open GL,
but for the more complex render modi it is using CPU.
Conclusion
Lesson learned - first make your homework and then start to build:)
No seriously, I'm very happy with the boosted performance in daily workflow.
For the renderings I will wait if Apple is coming up with a serious pro laptop in 2017,
if not I will swap to windows, go with a maxed out Lenovo P50 and optionally with a serious render workstation at home.
(which is only of limited use, as I'm travelling a lot in business an private)
I'd be grateful for shared experiences of other vectorworks users.
.Funny thing about doing your homework first. I do a lot of renderings so I looked for a machine with a lot of vram. I bought a pc gaming machine from eluktronics. Fabulous machine but when it came to rendering no speed increase from my 4 year old mac book pro. Because I learn after the purchase that rendering in my application renderworks with vectorworks is exclusively a cpu based process. Even worse, short of a 8 core dual cpu setup it is as fast as it is going to get unless I use some sort of gpu rendering software.
.How was that configuration in the end? I'm interested in setting up a pc to render renderings and this thread is very helpful to me. Thank you
.Vectorworks hasn’t changed much. You should have a fast GPU and 8 GB of vram to run the viewport without getting annoyed.
Standard rendering is still done on the CPU, and rendering speed scales linearly with more cores. Get an AMD multi core processor or at least a 10-core Intel processor to speed up CPU render times.
(Pricey) Lumion and Enscape GPU-rendering plugins are available for Windows setups with Nvidia GPUs.
sorry for the late response.
My configuration ended up with a 16" Macbook Pro, till this one I improved my Vectorworks render workflow, so it ran efficiently on my old 2012 MBP even without the egpu.
After all it was a very interesting and in other respects helpful excursion towards a diy egpu. I had fun building it, designing the Akitio thunder 2 Air intake and improve Airflow with a dual Noctua Fan setup, that got my Akitio Housing quiet even under heavy Load.
Keep an eye on VW21, I hope they will improve multi core support.
In general high clockspeeds and multiple cores will help. Get fast ram. Try to build with respect to future Upgradeability. If working with Vectorworks, try te VW Forum for hints on custom builds as well.
