2x mac mini 2018 active fan mod + razer x fan mod
mojomojo
(@mojomojo)
i would like to share my mods for mac mini 2018 and also for the razer x case with my vega 64 setup.
Priority was low noise, cooling external nvme ssd and got access to usb ports and not max out performance.
RISK - High Voltage / loose of warranty ... think twice.
First post, so I can't attach images Smile
inspired by this thread
https://egpu.io/forums/gpu-monitor-peripherals/mac-mini-2018-thermal-solutions-thread/paged/2/
First try, i am a fan of the "blow hole" but i don´t like to cut my table, so i try first to use a old mac mini as active cooling device.
Works very well but I was still missing the easy access of the USB ports and still no card reader... shame on you Apple.
Please do not hesitate to ask ...
1.Mod - old Mac mini case
Materials
Mac mini case
step up converter - i use the onboard usb to power the fan 5v to 7v, attached directly to the fan
12cm fan - i use low noise Noctua, 120mm fan fits perfectly into the case
hot glue - universal weapon Smile (strong but still removable with less effort)
soldering iron - attach fan and usb cable to step up converter
multimeter to set voltage or try and error / risk up stepper can to more then 12v, can damage fan
draught excluder for better air flow
(remove black bottom from Mac mini 2018 for better airflow)
2.Mod - iMac stand with USB ports and card reader
Materials
iMac Stand with USB and Card Reader - i use a spacegrey satechi one
12cm fan - i use low noise Noctua, 120mm fan (140mm should also fit)
hot glue - the universal weapon Smile
saw, dremel or hamster for cutting a hole ( i use a 120mm hole saw)
optional:
thermal pad for external ssd to attach to aluminium body of the stand
good place also to store  other things ... (hot glue is you friend Grin )
3.Razer X Fan mod
Materials
Noctua 80mm fan 2000rpm flx - working on high voltage device, do it on you own risk! - remove old one / soldering new one and use ultra low noise adapter - use 12v and ground
Noctua 120mm fan - just replace old one (no PWM needed, just flx fans)
soldering iron - attach fan power in the PSU
4. Mac mini - cooling with liquid metal paste
Materials
Thermal Grizley Liquid Metal Compound - best cooling solution, but not easy to use, be carefully
Alcohol to clean
screw driver kit to open Mac mini - ifixit guide is usefull
Benchmark:
Cinebench R20 2995cb
Thanks.
mojomojo
Mac mini 2018 + razer x + Vega 64 on 32" 4k | several other Macs
Thank you for sharing these very clever cooling mods! The CPU performance looks excellent. Funny how it slots right in between the Mac Pro 5,1 and 6,1.
mojomojo
(@mojomojo)
Yes, but top (non Apple) CPU configuration of the 5,1 is 2x x5690 with 3,46GHz, will be much faster then the 6,1 configuration and cheaper as the mac mini if you buy them used and upgrade by yourself... but nobody wants 150 watt idle anymore 😀 ... have one under my desk but i think the mac mini with egpu is better package now...
I agree the Mac Pro tower is much more flexible and affordable to modify. I still use a 5,1 single CPU tray as my macOS server. It handles Time Machine backup, NAS, Unifi controller, Plex, and other experiment projects. The 4 SATA bays are great for high capacity storage. For a desktop-use headless Mac, the Mac mini and Mac Pro trashcan are more appealing.
iaomw
(@iaomw)
Is that possible to power the fan from logical board or the internal dc header instead of USB?
mojomojo
(@mojomojo)
Yes, you can use 12V directly from the PSU, but you have to solder it or xyz and you have to pass trough the shield with the cable, the USB option is easy as possible and non destructive ... if you do not want to change thermal paste, the mac mini is still under warranty...
4chou
(@4chou)
Have any benchmark before using liquid metal? Liquid metal have very good performance but too danger.
Solid post and great solutions! Really like the stand option. I saw some posts on reddit where people had fitted the mini under/inside that stand which looked pretty cool but this extra cooling solution looks smarter.
itsage would love more info on your MacPro server set up and Unifi etc, would be interesting so see other peoples set ups beyond just eGPUs. A post aobut on it on its own would be cool IMO, I imagine we all have a similar interest in home networking.
(@dimitri_bolt)
@mojomojo
Hello, could you advise me if I need to blow In or out outside air?
