Hi everyone,
my ASUS XG Station Pro is not turning on anymore. When I shut it off yesterday, everything was working fine.
Power brick is obviously connected. Pressing the on/off button does literally nothing. The LEDs D40 and D42 on the left hand side of the board (D33005 RoHS) turn on when I connect it, but that's it. Maybe this is some kind of error code? They are hidden under the black cover with the two screws.
I'm thankful for any advice. Thanks.
.@marcus_1, Do a power reset by disconnecting the power cord from the power brick.
@itsage, I tried that already, but it had no effect..
