Belkin 2m TB3 cable is a winner
Trajans Row
(@trajans-row)
After experiencing disconnect issues with a Cable Matters branded 2m Thunderbolt 40Gb cable, I decided to try a Belkin TB3 cable of the same length. It's cheaper, too - $52 on the Apple Store.
So far, the Belkin seems solid with my tMBP and Core. The plugs on on the cable are longer than the .5m cable from Razer, which permits more leverage on the port. However, I was pull the cable 360 degrees around the port with no disconnects during a benchmark. It also looks to be charging the laptop, so it does carry at least some power. The sheathing is pretty flexible, making organization better.
Would recommend.
Have you confirmed it's a 40Gb/s cable? I got a Belkin 1m Thunderbolt 20Gb/s cable. It is slightly slower (about 10%) than the AKiTiO .5m Thunderbolt 40GB/s during benchmark. It was tested with the internal display on my 13" MBP with the Node.
ikir liked
dsaul
(@dsaul)
The 0.5m and 2m cable are 40GB/s. I wanted to by 1m cable coz of the price and would be ideal for me but it is indeed 20GB/s. Not sure why they don't make the 1m cable at 40GB/s.
2016 13" MacBook Pro [6th,2C,U] + GTX 1060 @ 32Gbps-TB3 (AKiTiO Thunder3) + Win10 // includes audio fix [build link]
Trajans Row
(@trajans-row)
I'm not sure how to tell in Windows what the negotiated TB link speed is, but a SteamVR benchmark on the internal LCD gives me the same results with both cables. It is also advertised to support 40Gb, so I have to assume the cable is capable of active mode.
Alec
 Alec
(@alec)
I have the same cable and get random crashes when playing games that use 100% of the GPU.
2016 15" MacBook Pro (RP450) [6th,4C,H] + GTX 1080 @ 32Gbps-TB3 (Razer Core) + Win10 [build link]
A bit of a contradiction to the opening post.
@tunatoro tested the Cable Matters 40Gbps 2m TB3 cable and got full TB3 performance as measured by CUDA-Z at:
https://egpu.io/forums/builds/acer-aspire-v17-nitro-black-editionakitio-nodegtx1070-win-10/
He previously tested the Cable Matters 20Gbps 2m TB3 cable and saw reduced performance in the above thread.
Francesco Ripa
(@francesco_ripa)
A brief comparison between the cable supplied with ADT-Link and the Belkin 40Gb/s cable:
ADT-Link
Platform 0 : Intel(R) Corporation
Platform 1 : Advanced Micro Devices, Inc.
Platform found : Advanced Micro Devices, Inc.
Selected Platform Vendor : Advanced Micro Devices, Inc.
Device 0 : Ellesmere Device ID is 000001456CE9B1C0
Build Options are : -cl-std=CL2.0
Build: _WINxx release
GPU work items: 32768
Buffer size: 33554432
CPU workers: 1
Timing loops: 20
Repeats: 1
Kernel loops: 20
inputBuffer: CL_MEM_READ_ONLY
outputBuffer: CL_MEM_WRITE_ONLY
inputSVMBuffer: CL_MEM_READ_ONLY
outputSVMBuffer: CL_MEM_WRITE_ONLY
Host baseline (naive):
Timer resolution 101.72 ns
Page fault 558.17 ns
Barrier speed 84.36 ns
CPU read 10.55 GB/s
memcpy() 8.64 GB/s
memset(,1,) 25.54 GB/s
memset(,0,) 27.15 GB/s
AVERAGES (over loops 2 - 19, use -l for complete log)
1. Host mapped write to inputBuffer
clEnqueueMapBuffer -- WRITE (GBPS) | 2105.193
memset() (GBPS) | 27.443
clEnqueueUnmapMemObject() (GBPS) | 2.740
2. GPU kernel read of inputBuffer
clEnqueueNDRangeKernel() (secs) | 0.003
Verification Passed!
3. GPU kernel write to outputBuffer
clEnqueueNDRangeKernel() (secs) | 0.005
4. Host mapped read of outputBuffer
clEnqueueMapBuffer -- READ (GBPS) | 2.857
CPU read (GBPS) | 9.720
clEnqueueUnmapMemObject() (GBPS) | 808.974
5. Host mapped write to inputSVMBuffer
clEnqueueSVMMap -- WRITE (GBPS) | 2444.273
memset() (GBPS) | 26.643
clEnqueueSVMUnmap() (GBPS) | 2.744
6. GPU kernel execution using inputSVMBuffer
7. GPU kernel write to outputSVMBuffer
8. Host mapped read of outputSVMBuffer
clEnqueueSVMMap -- READ (GBPS) | 2.852
CPU read (GBPS) | 9.463
clEnqueueSVMUnmap() (GBPS) | 920.701
Belkin
Device 0 : Ellesmere Device ID is 000001E6FDDA1990
CPU workers: 1
Timing loops: 20
Repeats: 1
Kernel loops: 20
Timer resolution 103.35 ns
Page fault 2167.87 ns
Barrier speed 356.73 ns
CPU read 8.63 GB/s
memcpy() 7.79 GB/s
memset(,1,) 23.62 GB/s
memset(,0,) 23.61 GB/s
clEnqueueMapBuffer -- WRITE (GBPS) | 3359.176
memset() (GBPS) | 27.255
clEnqueueUnmapMemObject() (GBPS) | 2.728
clEnqueueMapBuffer -- READ (GBPS) | 2.839
CPU read (GBPS) | 9.361
clEnqueueUnmapMemObject() (GBPS) | 935.677
clEnqueueSVMMap -- WRITE (GBPS) | 3108.491
memset() (GBPS) | 26.855
clEnqueueSVMUnmap() (GBPS) | 2.737
clEnqueueSVMMap -- READ (GBPS) | 2.844
CPU read (GBPS) | 9.604
clEnqueueSVMUnmap() (GBPS) | 976.997
[Please login to see this]
2021 Intel TB4 | i5-11400F 2,6 GHz - 16GB 3200 MHz DDR4 - NVMe 250 GB PCIe 4.0 - RX 570 4GB GDDR5
2019 MacBook Air (MacBookAir8,2, i5 1,6 GHz, 8 GB) + RX 570 @ R43SG-TB3
2010 21.5-inch iMac (Custom Build, i5 3,2 GHz, 12 GB, AMD FirePro M4000 1GB GDDR5)
