can my Egpu and intel nuc (mini-pc) be connected to the same atx power supply?
Moe Basalama
(@moe_basalama)
So I want to power my Nuc with ATX psu and the reason is I built my own egpu and i would like to throw the nuc in there powered by the same psu for the egpu which makes it a full small size gamic pc in a way.
the nuc needs= 19v maximum 10a maximum 120w
atx psu have 12v output so i thought i can use a step up to push it to 19v and hook that to the nuc somthing like this  https://www.amazon.com/DC-DC-module-152Wmax-supply-converter/dp/B00M3SR51Y/ref=pd_lpo_107_img_0/134-5039755-4302764?_encoding=UTF8&pd_rd_i=B00M3SR51Y&pd_rd_r=76357fcd-882e-4ff7-a35a-0c1838a5debf&pd_rd_w=vjM7d&pd_rd_wg=5tR29&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=PGYVCS1MXBF0NDW007ZJ&psc=1&refRID=PGYVCS1MXBF0NDW007ZJ
However how can i get that 12v out of the psu??? do i use the 24pin or the 4 pin and which wire do i need to use??
I found a lot of videos on youtube to change the Whole atx psu into 12v dc output (BUT THEY COMPLETELY USE THE WHOLE CAPLES BY CUTTING ALL THE PINS AND MAKE IT INTO DC OUTPUT WHICH MEANS I CAN NOT USE IT ANYMORE TO CONNECT EGPU TO IT) LIKE THIS
