dell 6rtjt power supply -> unsuitable 19.5V source
[Solved] dell 6rtjt power supply -> unsuitable 19.5V source
eight bit hero
(@eight-bit-hero)
hey everyone
 I'm new to this whole thing so bear with me if i sound dumb lol. i wanted to know if the dell 6RTJT power supply could be modded to work with the akitio thunder3. i have a skull canyon nuc w/ the thunder3 and a i want to use the gigabyte 1070 mini. i just think this power supply us thiner and nice then the hulking DA-2 and the R6TJT throws better power.
thanks
Plastixx
(@plastixx)
No.
The Akitio Thunder3 requires a 12V power supply. The 6RTJT is 19.5V.
2011 17" HP ENVY 17t-2100 [2nd,4C,Q] + GTX 1050 Ti @ 4Gbps-mPCIe2 (EXP GDC 8.4) + Win7 [build link]
eight bit hero
(@eight-bit-hero)
no i understand that i wanted to know is there to maybe regulate the power to go to the 12v and the rest go to a 6+2 pin set for the gpu
vava726
(@vava726)
Your solution is overcomplecated. It's simplier to redistribute  wattage than voltage because every component  (tb3 board 10w, pci-e line 75W and the gpu itself (depends)) requires 12 V.
I suggest you to use a small factor sever psu (if you need more than 220w) or the ugly but very efficient da-2.
eight bit hero
(@eight-bit-hero)
thanks for the reply so what kind of wattage would i need to fuel a 1070 mini?
Yukikaze
(@yukikaze)
Noble Member Moderator
The stock GTX1070 maxes out at 154W of power-draw (source here). A Dell DA-2 (220W) should do the trick.
23mrtbone liked
eight bit hero
(@eight-bit-hero)
hey yukikaze yea i been following you and enjoy for a while on here before i got an account awesome info but i was just trying to use that dell 6RTJT power supply because it was slim and a little nicer then the big brick DA-2 lol
Yukikaze
(@yukikaze)
The Dell DA-2 is quite a brick, agreed. But it is a 10$ brick that powers most video cards and has a lot of people using it (so it gives you a lot of pictures to follow to make the connector), hence the overwhelming recommendations it gets Smile
eight bit hero
(@eight-bit-hero)
lol very true i was just putting the idea out there
Posted by: eight bit hero
i can't post the link in here for some reason but the kareon kable has it up on there page
This AC adapter is 19.5V. It is unsuitable for use with any of these TB3 enclosures requiring a 12V input. As from here .
Original 240W Slim Dell 6RTJT AC Adapter + Free Cord
Feature:
Input: AC 100-240V, 50/60Hz
Output: 19.5V 12.3A 240W
Connector:7.4mm * 5.0mm
Color: Black
