GTX1060 w 120W power supply
naplox
(@naplox)
hey
I’ve ben searching the forums and understand that most go with 220W along with the GTX1060 in the AKiTiO thunder2. Though
https://egpu.io/forums/thunderbolt-enclosures/akitio-thunder2-and-thunder3-gpu-size-to-close-the-akitio/
Says it peaks at 122W. Now I already have a 120W charger so would it affect performance in anyway sticking to that?
The Thunder2 requires ~15W for it's operation, leaving you ~105W. If you experience instability or the power cutting out, especially under 3D load, then simply use MSI Afterburner to lower the GTX1060 power target, core & memory clocks by 15-20%.
Yukikaze
(@yukikaze)
Prominent Member Moderator
A GTX1060 requires an additional power input. You need to provide that somehow, or the card won't work.
