Help with GTX 1060 and PSU
TRUTH94
(@truth94)
hello everyone and happy new year Smile
So i have a few questions about connecting my future PSU with the EXP GDC adapter and a GTX 1060.
The GTX 1060 requires an 8 pin connector, the EXP GDC requires an 8 pin connector too, and im wondering if the cables provided with the power supply      https://www.evga.com/products/specs/psu.aspx?pn=41487990-ce9c-4d28-bc96-b628fcebe303  are the ones needed for the whole setup, and if not, which ones should i order...?
2011 15" ASUS K53SV [2nd,4C,Q] + GTX 1060 @ 4Gbps-mPCIe2 (EXP GDC 8.4) + Win7 [build link]
Torino1564
(@torino1564)
You have to plug the 24 pin + the 4 pin to the adapter that comes with the gdc and then plug it in the 8 pin of the gdc. Then you just need to power the gpu with the 6 + 2 pcie cable
Thats lucky
TRUTH94 liked
rena-s
(@rena-s)
please tell me. these empty pin duplicate food? over the green wire is for what pin?
IMG 20180203 192423
TRUTH94
(@truth94)
hey ty for your help, i have connected eveyrthing and it works fine Smile
TRUTH94
(@truth94)
@rena-s, no idea...dont get too focused on the cables, just connect everything and pray for it to work xD
