Long Thunderbolt 3 cables with full speed.
 of  6
thallium
(@thallium)
Hello
I'm looking for longer (1m-2m) cable for my Akitio node. Can You tell me whichone on the market will be best and will be work with full speed?
Thanks.
noler
(@noler)
I got mine (1m) from CalDigit:
http://shop.caldigit.com/eu/Accessories/Cables
Edit: They have a US store as well:
http://shop.caldigit.com/us/Accessories/Cables
2016 13" MacBook Pro [6th,2C,U] + GTX 1060 @ 32Gbps-TB3 (AKiTiO Thunder3) + Win10 // 120W AC adapter [build link]
thallium
(@thallium)
What do You think about this cable?
http://www.apple.com/shop/product/HKK22ZM/A/belkin-thunderbolt-3-cable-2-m?fnode=8b
noler
(@noler)
Posted by: thallium
It's probably a high quality cable. However I wanted a 1 m cable, that's why I went for CalDigit. Also it's only 60W charging power (if that matters to you) while the CalDigit is 100W.
ed_co liked
thallium
(@thallium)
Thank You very much for help. I will order this Caldigit cable in next week.
noler liked
Alec
 Alec
(@alec)
Posted by: noler
How well does that cable work, and what GPU are you using? I have an extra long cable from another company, but it's unstable and crashes my graphics.
2016 15" MacBook Pro (RP450) [6th,4C,H] + GTX 1080 @ 32Gbps-TB3 (Razer Core) + Win10 [build link]
ed_co
(@ed_co)
Posted by: noler
Posted by: thallium
Wow, what a bunch of specs... even for the charging power. I didn't know that this were changing from one cable to another...
2017 15" MacBook Pro (RP560) [7th,4C,H] + GTX 1080 Ti @ 32Gbps-TB3 (Mantiz Venus) + macOS 10.13 & Win10 [build link]
Username
(@username)
There are several manufacturers offering optical TB cables with lengths up to 10 meters. They are about ten times the price of an ordinary TB cable. And I have not seen them in TB3 specs yet.
BlackJack84
(@blackjack84)
You might want to check Nathan K and Benson Leung's list of approved USB-C cables&chargers here for detailed specifications and little-known flaws of each item.
Too bad it doesn't seem to include the CalDigit cables: if they're fully compliant with the USB-C/TB3 spec, with lengths up to 2m they'd really stand out.
Unless they are rebranded Belkin/Cable Matters cables, which wouldn't be good news (their longer versions are not recommended).
2021 14" Tongfang PH4TRX1 [11th,4C,H] + GTX1070 @ 32Gbps-TB3 (Mantiz Venus)
Username
(@username)
Here's one of the manufacturers.
Thunderbolt 2 up to 60 meter between computer and host.  https://www.corning.com/optical-cables-by-corning/worldwide/en/products/thunderbolt-optical-cables.html
And here's Delocks optical TB2 in 5, 10, 20 and 30 meters.
http://www.delock.de/produkte/suche.html
 of  6
