Mantiz Venus - USB-C long cable?
Brawl
(@brawl)
Hey,
I currently have a Mantiz Venus on my Macbook Pro (2017). The USB-C cable that came with it is ridiculously short so I want to replace it.
I  tried using the USB-C cable that the Macbook Pro uses to connect the power block to the laptop, and it doesn't work, so I presume it is not a USB-C cable? or there are different types of USB-C cables?
Anyway, does anyone know what cable I need to buy?
Many thanks
Nick
switch
(@switch)
There are multiple kinds of USB-C cables:
- charging only
- charging + USB (this is what apple supplies I think)
- charging + USB + thunderbolt
In order to use the TB3 functionality you need the latter. These USB-C cables are expensive and SHORT. Passive cables can be 50cm long at most (I am quite sure the Mantiz comes with a 50cm cable). In order to go beyond that you need ACTIVE cables. These exist in 1m and 2m flavors and both come with a disadvantage: they limit the max bandwidth (only a bit) and also limit the maximum PD - as they are power users themselves.
Look for USB-C cables with the numeral "3" inscribed next to the Thunderbolt logo. See here a sample image with a compatible cable:
2016 15" HP ZBook 15 G3 (Xeon E3-1545M, Iris Pro p580, no dGPU) + [email protected] (Aorus Gaming Box) + Win10pro
2018 15" HP ZBook 15 G5 (i7-8850H, HD630, Quadro P1000) + [email protected] (Aorus Gaming Box) + Win10pro
Brawl
(@brawl)
Great, thank you! really informative.
I will google about how much the bandwidth limiting will affect my gaming 🙂
switch
(@switch)
I would expect a few percentages of disadvantage when using an active cable compared to using the default passive cable. I would also expect much lower Power Delivery. If you have an 87W PD capable eGPU then expect 40~60W available to the laptop using active cables. IMO this might be the showstopper if you have a 45w CPU and are trying to game on the Laptop's display.
jefniro
(@jefniro)
I have the CalDigit cable, 2m with the number 3 on it like the picture above. I don't know if it's because I have changed the Akitio's PSU unit (450w Corsair) but the Thunderbolt cable gives  power to my macbookpro now... I don't know if the bandwidth is less than the one with the original akitio cable!
2016 13" MacBook Pro + RX 5700 XT @ 32Gbps-TB3 (AKiTiO Node) + Win10 1903
Rycco
(@rycco)
jefniro
(@jefniro)
Hi! As suggested by Nando (thank you!) I send to you my benchmark that has done with AIDA64, my configurations:
- MacBookPro 13" i7 Late 2016 with Touch bar
- Akitio Node
- XFX RX 480 GTR Black Edition (Damn....)
 CalDigit Thunderbolt 3 Cable - 2,0 m
Akitio Thunderbolt 3 cable - 0,50 m
memory write:
2464MB/s=2350MiB/s
memory write:
2507MB/s=2391MiB/s
Iris Graphics 550
@Jefniro,  your 0.5m and 2m cables perform pretty much the same. Your peak 2391MiB/s memory write is slightly higher than the peak I have on file for a Nvidia card for 32Gbps-TB3 here.
It’s all good 🙂
jefniro liked
jefniro
(@jefniro)
Posted by: nando4
@Jefniro,  your 0.5m and 2m cables perform pretty much the same. Your peak 2391MiB/s memory write ia slightly higher than the peak I have on file for a Nvidia card for 32Gbps-TB3 here.
It's all good 🙂
Good!! Thank you again as always!
jonwatso
(@jonwatso)
I only noticed a 1% drop in performance via benchmarking (valley) when using my 2M Cable Maters thunderbolt 3 cable. in real world use, there has been no real difference for me.
2017 15" MacBook Pro RP560 i7 3.1Ghz - 16GB RAM
Razer Core + Gigabyte Vega 64 8GB
Dell 4K DELL P2715Q Display
switch
(@switch)
PD will still suffer for active cables (lucky for us most laptops don't need more than 60-ish watts). Thanks for real-world numbers on PCIe cables!
rushvora
(@rushvora)
I ordered this cable 2 months ago, performance has been the same as the bundled short cable.
https://www.amazon.com/gp/product/B01H5QF2TK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
late-2016 15" MacBook Pro RP455 + [email protected] (Mantiz Venus) + Win10 // external SSD
Wunair
(@wunair)
Has anyone tried this CalDigit TB3 cable for the Mantiz Venus? I'm reading that it doesn't work with charging and passing data (one or the other will drop).
Reference
jefniro
(@jefniro)
My 2m thunderbolt 3 cable from Caldigit is burnt!! It doesn't work anymore, if I connect my Node troughs this cable the system says to me that I need to connect my device to a Thunderbolt port. Check the image!
caldigit
ed_co
(@ed_co)
What did you get jefniro? Caldigic again? Or tried another brand?
mid-2017 Macbook Pro RP560 + MSI GTX 1080Ti Gaming [email protected] (Mantiz Venus) + macOS10.13 & Win10
jefniro
(@jefniro)
They have changed it because the warranty, I have paid only the shipping costs because they wanted the damaged cable back.
ed_co
(@ed_co)
