TB3 Active cable performance
teltersat
(@teltersat)
Hey guys, I have a question that has been digging through my brain for quite a bit. Is there any performance degradation when you use a long TB3 Active cable (2m) vs a short passive one? (50cm). I'm asking because the way my setup is laid out I really need the 2m cable, but I'm not sure if I'm being penalized for it...
MacBook Pro Touch Bar 2017 15" + Mantiz Venus MZ-02 + AMD Radeon Vega 64
2017 15" MacBook Pro (RP560) [7th,4C,H] + RX 580 @ 32Gbps-TB3 (Mantiz Venus) + Win10 [build link]
DrEGPU
(@dregpu)
I can give it a try tonight or tomorrow. I've been using a short passive cable with the Razer core X on my desk. I have a 2m active cable on hand. It would be nice to reclaim some desk space!
2021 13" Framework Laptop [11th,4C,G] + RTX 3090 x4 @ 32Gbps-TB4 (Razer Core X) + Win10 21H1 // first four GPU TB4 build [build link]
odin
 odin
(@odin)
I don't think there is a difference. You can always buy it and do some benchmarks, return it if there's a large dip. Frankly I'd probably just use it and see if you NOTICE anything. Benchmarks are good for comparisons, but it's really more important how you feel using it.
2018 17" LG Gram 17 [8th,4C,U] + RTX 2070 @ 32Gbps-TB3 (Sonnet Breakaway 550) + Win10 [build link]
I don't think cable length matters. Speed of electricity is very fast. an extra 1.5m will add up to a handful of micro seconds to the time it takes for a bit to reach the other end. This is not a problem because many bits are sent before expecting a reply.
Problems can arise if the extra length adds errors but the active part of the cable handles that.
https://9to5mac.com/2018/08/23/back-to-the-mac-011-are-longer-thunderbolt-3-cables-slower-video/
Drop in performance happens when you chain multiple Thunderbolt 3 devices together.
2m active 40Gbps TB3 cable benched giving full H2D bandwidth at:
https://egpu.io/forums/builds/acer-aspire-v17-nitro-black-editionakitio-nodegtx1070-win-10/#tb3-cables
Bandwidth would not be an issue between active vs. passive. I'm interested in seeing latency differences.
cuppino
(@cuppino)
Posted by: @teltersat
I'm using this ( https://www.belkin.com/us/p/P-F2CD085/) and I'm finding it great!
I haven't had any performance loss, on the contrary it's all very stable!
You can also find it on the apple website. I bought it there.
iMac 27" 5k 2019 (i9 9900k 3,6ghz, 40gb ram ddr4 2666 mhz, ssd 1tb, dgpu Radeon pro vega 48 8gb), Egpu: Razer Core X with ZOTAC GAMING GeForce RTX 3090 Trinity
Osx 10.15.7
Windows 10 pro 2004 - Bootcamp
esatamacmodular
(@esatamacmodular)
Posted by: @cuppino
link does not work for me...
So people like the belkin and cable matters. Where does that leave the akitio one?
https://www.akitio.com/cables/40gbps-thunderbolt3-cable-2m
cuppino
(@cuppino)
Posted by: @esatamacmodular
Posted by: @cuppino
I send you the link to the Apple store. https://www.apple.com/shop/product/HMBH2ZM/A/belkin-thunderbolt-3-5a-cable-2-m?fnode=e5656ecb271d658a9f3d405dc15561e3bf9726a4f69cef69ca98fa108f643cd61956a251d268acb3a18bce582a6326de4ef61eb3049929d43bed4c429daf46b79643cc6e0227758464f794b4ccda862598c4852f4b26a3a7f548990e7f70f65b
has the same features as the belkin cable.
I preferred the belkin because I knew the brand.
With my razer core x it works perfectly.
Osx 10.15.7
esatamacmodular
(@esatamacmodular)
@cuppino
Ok thanks, I see these specs listed for belkin and then akitio - both 2m cables:
Belkin
Thunderbolt 3 male to Thunderbolt 3 male connectors
Transfer data at up to 40 Gbps
Connect to Thunderbolt 3– or USB-C–enabled devices and displays
Supports Thunderbolt/HD displays
Take advantage of up to 100W power delivery
Thunderbolt certified
Akitio:
  • Lightning fast data transfer rates up to 40 Gbps
  • Supports Thunderbolt™ and USB 2.0 protocols
  • Supports power delivery up to 100W
  • Reversible USB-C connector
maybe the belkin is more versatile?
