Which cable do I need? (Akitio Thunder3 + Dell DA2)
noler
(@noler)
January 30, 2017 8:55 am
I have a 8 pin Dell DA2 and a Akitio Thunder 3.
I'm planning to use a half length GTX 1060 with it.
My question is which custom cable I need to power my Thunder3 and GTX 1060 with the Dell DA2.
Will this do? Or do I need another cable from the site? (I rather not solder one myself).
2016 13" TB + Akitio Thunder3 with EVGA GTX 1060
theitsage
Famed Member Admin
January 30, 2017 5:30 pm
The custom pre-built power cable you linked should work.
68 external GPU build guides
noler liked
Excalibur
(@excalibur)
January 31, 2017 1:55 am
http://kareonkables.com/products/dell-da-2-akitio-thunder2-box-62-pin-pci-e-with-25mm-adapter
this one seems better as the output is 6+2, so you can use GTX 1070/1080 with DA-2
with 6 pin output you can only hook up GTX 1060
Current: Thinkpad W540 - i7 4900MQ - 32 GB DDR3L - Quadro K2100M - Akitio Thunder2 - GTX 660 OEM
Retired: Thinkpad W520 - i7 2860QM - 32 GB DDR3L - Quadro 1000M - EXP GDC Beast - GTX 560 Ti - GTX 660 OEM
noler liked
noler
(@noler)
January 31, 2017 9:56 am
Posted by: Excalibur
Yeah I went for 6+2 🙂
kiodos
(@kiodos)
February 21, 2018 5:22 pm
Hello,
I would like to come in this discussion because I am planning to install a gtx 1060 mini inside an Akitio Node  Lite enclosure, as I understood, identical to the Thunderbolt 3.
I have two questions then:
- Have the Node Lite, Thunderbolt 3, etc enclosures some pins inside the case in order to supply the electronics of the enclosure directly from the GPU supply cable or I am actually obliged to use the external jack ?
- Through the Dell DA-2 "system", can we finally close the enclosure or because of cables it will be an open configuration?
Thank you!
2017 13" Macbook Pro Touchbar + GTX1050Ti@32Gbps-TB3 (AKiTiO Node Lite) + macOS 10.13.15 (macOS-eGPU.sh)
Nvidia Web Drivers 387.10.10.10.30.107 + CUDA Drivers 396.64
February 21, 2018 6:38 pm
@kiodos, please review the AKiTiO mini-eGPU thread to see examples of matched video cards and low profile PCIe connectors to allow the AKiTiO outer cover to slide over the chassis:
https://egpu.io/forums/thunderbolt-enclosures/akitio-thunder2-and-thunder3-gpu-size-to-close-the-akitio/
Also please consider the similar priced Zotac Box Mini as an enclosure candidate.  It is taller, comes with a 180W AC adapter and an internal 6P PCIe connector as standard:
https://egpu.io/forums/thunderbolt-enclosures/unboxing-zotac-amp-box-mini-thunderbolt-3-egpu-enclosure/
eGPU Port Bandwidth Reference TableeGPU Setup 1.35Several build guides
2015 15" Dell Precision 7510 M1000M + macOS 10.13.6 & Win10
kiodos
(@kiodos)
February 21, 2018 7:00 pm
Thank you for your reply,
what I didn't find is an high resolution pic of the interior of the Node Lite, so I didn't understand from the forum if a pin connector was installed in the internal board or not.
From you answer I guess no...so for high powered GPU a custom cable that supplies GPU and splits in two by exiting and suppling the whole enclosure though the jack is needed , this cable should be flat (as those of kareonkables) in order to slide the chassis.
Linked question: this customized cable exit from the back of the enclosure, but where ?
Alternative: supply 120W by the jack and install a less powerful GPU as the 1050Ti.
Too bad for the Zotac Box Mini as in a moment of enthusiasm I ordered the Node Lite....
