Aikitio Node Pro – PSU fan not spinning
MacBowtie
(@macbowtie)
I purchased a used Aikitio Node Pro and fitted it with a XFX AMD 580. The setup works fine (though still need to iron out a few glitches).
The enclosure fan is spinning OK, at constant speed. But the PSU fan hasn't spun at all so far. Is this normal? Does it only kick in above a certain temperature?
Many thanks!
2018 MacMini i7 / Mac OS Mojave / 4k iiyama screen
Topic Tags
@macbowtie The PSU should be running when it's connected to a Thunderbolt 3 host. That behavior does not seem normal.
MacBowtie
(@macbowtie)
@itsage I did a GPU performance test with Unigine Heaven, and the PSU fan starts running as soon as I put enough load onto the GPU, and then stop again shortly after I quit Heaven. Could it be that there has been a quiet update to the Node Pro's PSU?
