Mounting a hybrid radiator in the Node results in the case not being able to close properly. If you inverse the mounting bracket you can rotate the fan 90º, and the case closes properly.
This means the hoses are then either above or below the radiator rather than on the side. Is this a bad idea?
.Placing the radiator so that the hoses stay on top would be the best option imo.
That's what I went with. Having the hoses on the bottom cramps them up against the side of the GPU too much. Just want to make sure there isn't any issue with trapped air at the wrong point/pressure on the pump/etc.
.That's a good plan. We'd love to see pictures of your setup!
.Sexy!
Nice Curious did you use Node's fan or Evga's Fans? I'm going to install hybrid on Akitio node next week
thanks
.hello all
here is my setup - 2*120 mm noctua push-pull with msi 1080 sea hawk
some mods to case has been done..ale power supply fan replaced with silend one running at 9v,
so far, at closed akitio, 3 hours of heaven bench, 49 degrees max at 22 outside temp.
so far, happy
.Your eGPU got a lot of fans! 😀
Thanx for the pictures, somewhere I prefer to let it open, I suppose that with the water cooling no need to close the box.
MBP 2018, Touch Bar, i7 2.6 GHz, 32 GB RAM, 1T SSD, Radeon 560X... very nice!
eGPU : Akitio Node + RX 580 + GTX 980 Ti + Vega64
