On reddit, /u/kingnever came up with the idea to connect a TB3 dock to the downstream TB3 port of the AKiTiO Node Pro in order to provide a second TB3 controller to which peripherals will be connected. The end result is essentially a setup similar to the one utilized by the Razer Core V2, providing the load balancing required to stop things like mice and keyboards from stuttering. Of course, the Core V2 is extremely expensive at 500$, so adding a dock to the Node Pro is an attempt to get the same benefit cheaper.
For the simplest setup, you would need to get a mobile TB3 dock, such as this: Cable Matters Thunderbolt3 Multiport Adapter. Then you need to add aΒ (preferably powered) USB hub to create additional USB ports. This would add about 125$ to the Node Pro cost (110$ for the dock and another ~15$ for a powered USB hub if you do not have one already), making the total setup 455$. This is still cheaper than a new Core V2, but not by that much.
Since I have a Node Pro as my primary eGPU box, I wanted to try to do it cheaper, by leveraging a used HP Elite Thunderbolt3 Dock. These are available for under 40$ on ebay. I got mine off this listing for 30$ via "Make Offer". They have 4 USB ports and a headphone/microphone combo-jack, as well as yet another downstream TB3/USB-C port, which should be sufficient for at least the basic peripherals, so another USB hub is not a must.
30$ is of course a lot less than 110$, but you still need a power supply and a TB3 cable. The power adapter is a regular "new type" HP laptop power supply, which is the thin blue barrel plug that the newer non-USB-C charging HP laptops come with. It originally comes with a 65W brick. You can pick up a compatible power supply off ebay for 10$. I happened to have a spare one, so that was easier for me. Next is the TB3 cable: You can pick up a passive 20G cable (and you don't need more than this here anyway) for 10$ off Amazon. If you, like me, replaced your eGPU's original cable for a longer one, then you already have a cable you can use.
The end result costs 330$ for the Node Pro, 30$ for the dock, and 20$ for the TB3 cable and the power supply, for a total 380$ (and less if you have some spares), which is 120$ cheaper than a new Razer Core v2. I have set mine up yesterday and I can confirm that my mouse and keyboard are working reliably.
The same should work with any other enclosure that has a downstream Thunderbolt port.
@yukikaze This is an excellent find! I was not aware there's a downstream TB3 port. Do you know if it has Power Delivery? Potentially we could daisy-chain a single I/O to this TB3 dock to not only get stable expansion port but also charging.
β’ external graphics card builds
β’ best laptops for external GPU
β’ eGPU enclosure buyer's guide
That port should have power delivery, but I am not sure how much exactly (I would guess 45W or 65W). I'll check if it charges my Pixel 3XL (the Pixels use USB-C power delivery, as opposed to a QC or regular USB charging standard) later today, but that is not exactly a very power hungry device.
As a silly thought, I wonder what will happen if this port on the dock would be connected back to the 2nd TB3 port of the host system...
Can you attach a photo of the power and TB3 connection? The sunk [Power + TB3] combo is confusing me. I saw photos of different Thunderbolt 3 power cable for this dock and it's not clear either.
Personally I use something similar but no daisy chaining. My TB2 akitio thunder2 on the top left port of my 2017 MBP 15" and the Caldigit TS3+ on the top right. Haven't had any stuttering in my peripherals and external drives on both macOS and Windows 10. I use about 13 of the 15 ports. When I upgrade to a TB3 eGPU I was going to see if I could daisy chain but PD to the MBP is a hurdle.
Mid 2017 15" MacBook Pro > ASUS XG Station Pro > RX 5700 XT > 34" 2560x1080 Ultrawide
@itsage it's all in the Manual: the TB3 port is unpowered. The TB3 port is powered: it provides 60W (to my non-HP laptop) like the Node Pro.
The TB3 + power -> TB3 cable is certified up to 65W. The TB3 + power -> TB3 + power cable is for 150W / 200W.
Manual is here: HP Elite Thunderbolt 3 65W Dock - Manuals, See "Setting up the dock", page 5 for the details about cables.
Β
@yukikaze, sadly it doesn't work for me: those mice and keyboard stuttering arises when I use this dock in either way.
I updated it's firmware from 16.x to 27.x (from: HP Thunderbolt 3 Dock β Firmware version 1.77 Rev.A).
My Node Pro is at 23.00.
I tried:
- host -> Node Pro (GTX 970) -> HP dock: it have H2D ~2000 MB/s and D2H ~ 2600 MB/s ... and the stutters.
- host -> HP dock -> Node Pro (GTX 970): it works
it has H2D ~2000 MB/s and D2H ~ 2600 MB/s also, but the stutters are present too πΒ
I used Startech 100cm 100W and Node Pro's 20cm cables.
Β
So I had to rollback to an USB-C mini dock (3xUSB3.0 + GBit Ethernet + HDMI).Β It doesn't have stutters, but it's always on because of Node Pro charging feature.
Β
Β
