July 1, 2020 8:02 pm
Hi All,
I have the Akitio Node Pro (500W PSU; nearly 400W dedicate to the GPU). Paired with an MSi RTX 2080 Ti Duke OC which only needs 275-350W of power depending on overclock settings.
The GPU is stuck at the base clock 1350MHz instead of boosting to over 1600MHz under load. Has anyone encountered this problem before?
(running windows 10)
