Anyone can help me ,the issue with aorus gamingbox
Alex Zhan
(@alex_zhan)
hello all, recently I got a used-gigabyte aorus gamingbox 1080ti enclousure. The device has been mod by the owner(he removed the orginal graphic card and use a pcie link to support the largest card.) I have 2 graphic card and both were works fine. one is sapphire rx580-4g oc   another is amd rx6800. and also I have  another thunderbolt enclosure the mantiz vens. when i plug in rx580 to the aorus.and rx6800 on mantiz. they both connect to my nuc11-tigerlake through the tb3 port.It works fine(30%) ,or  gets stuck and the screen will black and can not nothing but reboot by holding the nuc power( about40% ). another situation is the screen will get black and amd driver will display the timing out message and after wattman reset ,the system will still work.(30% ). So I think maybe the enclosure have some issue. or just the system is not compatible? If I use only mantiz with my rx580 , it works fine . if i use mantiz with rx6800, it works fine too, if i use aorus with rx580, it will get stuck. if i use both .the same stuck . So after what i discribe. anyone can tell how can i solve the issue? Is there any possible that the aorus's power unit have issue? should i buy a new flex power supply? or this just the compatible issue? anyone can give me some advice? thanks you very much!
555
777
4444
3333
the blue chart is arous and red chart is mantiz.
[Please login to see this]
ps: If the system with both enclosure plug run after a while and with no stuck, then it will never stuck .If i use rx6800 to mining crypto and rx580 gaming. it works fine. but ,I can not reboot .because if i reboot .mybe next time  it will stuck. so is this can tell that the psu of the aorus is fine ?
macbookpro 15" late2013 Mantiz Sapphire Rx480 Xfx Rx5700
2021 Intel NUC11TNKI5 [11th,4C,G] + RX 6800 @ 32Gbps-TB4 (Mantiz Venus) + Win10 [build link]
@alex_zhan, From the symptoms you described, it's unlikely to be a power supply issue. Have you tried hot-plug the Gaming Box to the NUC without any GPU installed? You'd want to established the Thunderbolt 3 connection between your NUC and Gaming Box is functional. Next step is to test with adding the GPU through hot-plug. Booting with multiple eGPUs can cause hang due to firmware compatibility. Therefore it's best to test with each configuration through hot-plug to confirm. Also helpful to make changes in the BIOS.
2020 Gigabyte Z490 Vision D [10th,8C,K] + RTX 2080 Ti @ 32Gbps-TB3 (AORUS Gaming Box) + Win10 2004 [build link]
Alex Zhan
(@alex_zhan)
@itsage
thank you for your reply itsage, now i am 100% sure that the issue is about the gigabyte gamong box. cause i swith the rx580 to mantiz to link my nuc , they just works fine. and if i link the nuc with the arous gamingbox. then maybe it will get stuck . Is this just the compltible issue ? this device is about 85usd. is it worth to spend more time to figure it out? It is very upset that 20-30times reboot a day. need your advice. thanks
@alex_zhan, The Gaming Box PSU and mainboard don't always work with different graphics card. You may need to supplied 12V to PCIe slot pin 1 [link].
Alex Zhan
(@alex_zhan)
@itsage, Thank you. After I try link my monitor through my nuc hdmi port(just like the intenal mode as a laptop). The both egpu graphic cards work as a extenal mode  and I have try many times reboot. It seems the system will no longer get stuck anymore. Well, this can be a sloution for me .Maybe the gaming fps will drop a little, but i am ok with it. Just let everybody know what happened.
conclusion:
link gamingbox (rx580 4g) with monitor   : get stuck
link mantiz(rx580 4g) with monitor: not get stuck
link mantiz(rx6800 16g )with monitor: not get stuck
link nuc with monitor and one or two egpu as external : not get stuck yet.
