Aorus Gaming Box 1070 / Yoga 920 H2D issue
wmpt
 wmpt
(@wmpt)
I`ve been looking for an answer for this problem but so far haven`t found a working solution.
Specs:
Yoga 920 / i7-8550u, 16gb, UHD, Windows 10 64bit
Aorus Gaming Box 1070 (included 50cm cable and Choetech 200cm)
Issue:
- H2D speed (CUDA-Z) ~1500MiB/s
Fixes already tried:
- BIOS updated xxx28xxx->xxx29xxx -> xxx36xxx   - Same problem
- Yoga thunderbird firmware updated to latest - Same problem
- Aorus firmware updated to H2D 1.0 (couple of times) - Same problem
- Thunderbolt updated to latest (and tried older aswell) - Same problem
I`m sure there is a way to get the full H2D speed but I can`t seem to find the the solution. Can somebody suggest a working one?
Flyer
(@flyer)
I have the same laptop with the Auros 1080 gaming box.
https://egpu.io/forums/builds/yoga-920-auros-1080-gaming-box/
What is the link to the specific CUDA-Z software which measures H2D?  I'll run the test and see if my # is the same as yours.
How do I check and/or update the Auros firmware version?
2017 14" Lenovo Yoga 920 [8th,4C,U] + GTX 1080 @ 32Gbps-TB3 (AORUS Gaming Box) + Win10 [build link]
wmpt
 wmpt
(@wmpt)
The program can be found here:
http://cuda-z.sourceforge.net/
Check your results. These 920´s should get over 2000MiB/s
Flyer
(@flyer)
Thanks, but Norton Security uninstalled this file as soon as I downloaded it.  Are you running AV, thoughts?
Norton uninstall
Flyer
(@flyer)
Thoughts?
Cuda Z Performance with H2D 2
Cuda Z Memory 2
Cuda Z Core 2
