AORUS Gaming Box: What GPUs do work, and which ones do not?
 of  15
Invoker
(@invoker)
@arzen,  Yeah, soldering under the board. This method can provide fastback to factory state - just cut the wire Smile
Screenshots:
IMG 4858
IMG 9175
Username, Arzen and itsage liked
Arzen
(@arzen)
@invoker,  Nice work! Thanks for sharing.
MacBook Pro 16" - 2.3 i9, 16GB, 1TB, 5500m (I added thermal pads to the VRMs); Mantiz Saturn Pro w/ PowerColor Red Devil 5700 XT (previously, a Gigabyte RX 580 Gaming Box) + LG OLED C9
typer77
(@typer77)
My apologies guys. It's v late at night and I have rushed through a few threads. I am still confused if a factory rx580 AGB can be upgraded to Nvidia card, say 1070 or 1080?
I mainly use windows laptops...
I am about to buy one off a seller locally in 12 hours so I need some quick answers. Thank you in advance!
everton.correa
(@everton-correa)
Posted by: @truong_anh_atikaka
im using  a riser, my card is 1050Ti gaming X full size, and it work well with my macbook pro 2016 13'' non touch bar
pic here https://www.instagram.com/p/BmoIC-CFCMc/?taken-by=truong.ati
@truong_anh_atikaka
How did you made the MacOS work with a Nvidia card?
I have the original  GTX 1070  and I'm buying the  Macbook Pro  16". My concern is how make this card work on MacOS.
everton.correa
(@everton-correa)
Posted by: @jbpritch
I can confirm the gigabyte rtx 2060 mini works great in an AGB that originally had a 1070.  The H2D firmware for the 1070 also worked great.  I used this setup on both a matebook x pro and 2019 razer blade stealth.  For $470 it is a powerful mobile gaming setup ($350 for 2060 and $120 for AGB).
How did you get the MacOS working with the GTX 1070? Because I saw that MacOS don't support Nvidia cards.
jbpritch
(@jbpritch)
@everton-correa, I used it on a xiomi *matebook* not MacBook. Sorry
Leandro Glossman
(@leandro_glossman)
I can confirm that the Gigabyte RTX 2070 v1 works just fine on a Gaming Box which originally came with a 1070. My only problem was the PSU died after 1 month of light usage, but I'm not sure if the 2070 was the cause since heat was pretty much the same between both. I had to buy an external ATX PSU since I couldn't find a replacement for the original.
Macbook Pro 2019 16" + Aorus Gaming Box upgraded with regular Gigabyte RTX 2070
Oculus Quest + Link
ondert
(@ondert)
Anyone tried RX 5600 XT itx with RX 580 Gaming Box? Does it work without the 12v trick?
@ondert, I tried RX 5600 XT ITX inside the Gaming Box. It would need the 12V mod to work.
jisongkun
(@jisongkun)
bought the 5700 itx version before I dig into the post much. i thought only soldering one cable is enough, apparently not. can someone help me to point out exact PCIE riser pin to solder which cable I need to solder to? thanks.
the moding i have done so far and the card I bought:
6C13CACB 8EEB 46E7 86F0 8D62FEB22E9D 1 105 c
67DB9D7F D626 4C01 B3EA 03151F58860C 1 105 c
 of  15
