Best 12V DC power connectors? most Barrels are rated at
[Solved] Best 12V DC power connectors? most Barrels are rated at
Spud_egpu
(@spud_egpu)
Hello all,
Any one have a good suggestion for what power connector to use in a external brick powerd egpu like the Node Lite?  The Node Lite has a 10A rated Barrel connector which is not enough.  I would ideally like something with a face size that would fit in the carrier sheet metal gap so ~1cm x 1cm.  Since the interior is going to be re wired anyway I am not too concerned about pcb mount...
Thanks,
Spud
Prominent Member
@spud_egpu duplicate question with some answers at akitio-thunder-2-barrel-plug-bypass
