BSOD when plugging Razer Core X Chroma into Razer Blade Stealth 2019
Leon Woodward
(@leon_woodward)
Hi guys,
I've a Radeon R9 280 installed in the Razer Core X Chroma eGPU which is connected to my Razer Blade Stealth (2019) via the included TB3 cable.
Drivers are up to date from what I can tell and the eGPU is working just fine, however if I stick the TB3 cable in while windows is up, the device will either immediately BSOD with error "driver verifier dma violation", or it will connect & disconnect 3 or 4 times before BSOD.
Removing the TB3 cable while windows is booted does not trigger BSOD. Restarting with TB3 Cable in works fine. It is only if I stick the cable in while the laptop's humming away.
I've tried with peripherals connected and with none connected, I've tried disabling the MX150 but still same issue
Any ideas?
Thanks
Leon
Laptop: Lenovo X1 Extreme Gen1 w/ i7-8750H GTX 1050 Max-Q dGPU
eGPU Enclosure: Razer Core X Chroma
eGPU: RX 5700XT
Cable: Caldigit 2m TB3 Active Cable
2018 15" Lenovo Thinkpad X1 Extreme (GTX1050Ti) [8th,6C,H] + GTX 960 @ 32Gbps-TB3 (Razer Core X Chroma) + Win10 [build link]
Leon Woodward
(@leon_woodward)
Update- I have installed a GTX 960 instead of the Radeon R9 280 with fresh drivers.
Behaviour is similar, however I no longer get BSOD upon hot plugging the eGPU into my laptop. Now the Nvidia driver is simply unrecognised and my laptop continues using the MX150 dGPU.
If i repeatedly plug in and out (giving a few mins between hot plugs) I invariably get BSOD.
The best thing however, is that from what I can tell, the very first hot plug after a reboot is successful. So if I start my comp from cold, realise I have not plugged in eGPU and then I do so- all good!
If I were to unplug my laptop while hot, show someone a funny video in another room, return and replug the system will not recognise the GTX960- and will eventually BSOD if I keep trying.
ugh!
eGPU: RX 5700XT
This sounds like driver conflicts. Run DDU to remove AMD & Nvidia graphics drivers. Also disable Windows auto driver install feature in DDU. Restart once all drivers are removed. When you have same brand dGPU and eGPU, it's best to have both active (check Device Manager) before installing the latest graphics drivers.
Leon Woodward
(@leon_woodward)
Hi, its been a few weeks of me working woth Razer support to resolve this and I'm no closer. Current set up is the same, gtx 960 in the core x chroma connected to the RBS 2019. Behaviour is also the same, BSOD when i hot plug the chroma in (no prob from cold boot).
Ive reinstalled every driver at Razer's direction, including the TB3 drivers. I've updated BIOS, restored windows to recovery point and tried changing bios settings, no change and Razer at this point seem to be at a loss.
Is there anyone else who has similar issues? Ill be looking for a warranty replacement soon if the issue cant be resolved.
Cheers
Leon
eGPU: RX 5700XT
Cliptags
(@cliptags)
Did you ever get this solved? I have the same issue. My razer blade 15 with an external 2080ti in my Core Chroma X enclosure crashes to a BSOD with a driver DMA verification problem. Razer recommended using the gpu switcher tool but that doesn’t seem to work. Any thoughts?
Leon Woodward
(@leon_woodward)
Hi, in the end- no I didnt. Razer were really underwhelming. Luckily I bought through Ebay and was able to return the laptop- I think it was just a lemon. Beautiful laptop but so many issues.
I have since replaced the RBS with a lenovo X1 Extreme (arrived yesterday). I uninstalled all drivers using DDU, rebooted (with the Core X chrome plugged in) and installed a fresh driver for the internal GTX 1050 Max q (as it is more recent than the 960). Everything worked as I had hoped- no BSOD and fully functional GTX960 eGPU. phew! I will put up a full build once I'm done tinkering.
I would recommend in your case downloading DDU, rebooting to Safe Mode and running it, then totally remove all drivers for the 2080 & the internal dgpu. Once done, restart with the chroma plugged in. You should find in your device manager upon reboot 3 display drivers, the integrated intel one, and then two generic ones for the 2080 and the dgpu (says something like unkown or generic or something to show no drivers)
Download the latest Nvidea driver and install it- both the dgpu and the egpu should both use this same driver, and will prevent the BSOD issues hopefully!
Good luck and dont bother with Razer support- they're not trained well enough to assist
eGPU: RX 5700XT
