Cooler Master EG200 - usb problems
Badea Cosmin Gabriel
(@badea_cosmin_gabriel)
dear all,
I own a CM EG200 since a couple of months, but only today I tried to check the usb ports functionality.
I connected a mouse and also a usb stick but nothing works. I can see that the lights on the mouse or stick turned on though.
This is my enclosure
Do you have any suggestions ? or could be a "general" issue of the enclosures ?
Thanks
2021 14" Lenovo Yoga Slim 7 [11th,4C,G] + GTX 1660 Ti @ 32Gbps-TB4 (CM MasterCase EG200) + Win10 20H2 [build link]
Boltoway
(@boltoway)
@badea_cosmin_gabriel, This might be a stupid question, but did you plug the USB Hub in? It is a seperate cable to the Thunderbolt 3 connection.
2021 14" Lenovo Yoga Slim 7i Pro (MX450) [11th,4C,H] + RTX 3060 @ 32Gbps-TB4 (AORUS Gaming Box) + Win10 21H1 [build link]
@boltoway This might be a stupid answer, do I really need a hub in order to connect the peripherals to the enclosure ? actually I was connecting each device to the enclosure.. hoh !?
Boltoway
(@boltoway)
@badea_cosmin_gabriel, If you want to use the USB Hub you have to connect the optional USB Cable:
eg200 webpages 4000x4000 gallery 15 zoom crop
@boltoway and if I want instead to use the usb 3.0 ports  ? what's the usage of those one ?
Capture
Boltoway
(@boltoway)
@badea_cosmin_gabriel, If you want to use the USB 3.0 Ports, you have to connect them via the port directly below them:
eg200 webpages 4000x4000 gallery 15 zoom 3
@boltoway, let me try and thank you !
Boltoway liked
